Pavan Pal
Rep Power: 4 ![]() |
I am a beginner to CFD and I am trying to become familiar with SU2. I am not completely understanding the configuration file. Can someone please explain to me or link me something that can help with the customisation for configuration files. Any guidance will be much appreciated. Thank you |
na
Rep Power: 8 ![]() |
welcome to CFD and SU2 ![]() I would say the best approach is to start from an existing cfg file. For that you might want to first to look at our tutorials which go into detail for some options https://su2code.github.io/tutorials/home/ . More cfg files are in the code-root under /Testcases/ in multiple subfolders. So depending on Internal vs external, Compressible vs incompressible, etc. you can find a good baseline there. You'll find more information on many options here https://su2code.github.io/docs_v7/Configuration-File/ and in the subsection you see there on the left which go into detail. I hope that already gives you some pointers. Tobi |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
