Prediction of Cl max in SU2 is higher than fluent |
October 12, 2021, 07:43 |
charan
Rep Power: 5 |
Hi everyone,
i simulated a small aircraft geometry in su2 and compared it with fluent. it is simulated for 1million Reynolds number, Mach number=0.1. i have use compressible SST, with FGMRES & LU_SGS, ROE scheme. the solution is getting converged in 600 iteration but i have noticed that SU2 is predicting Stall angle AoA=18, while fluent is predicting stall at AoA=14. and i have post processed the data where it is noticed that su2 is predicting more skin friction coefficient than fluent but interestingly the Cd is predicted similar to fluent. the following are my question: 1) is this prediction of more cl prediction is common in all flow regimes of su2. 2) if so, what could be the possible reason for it? 3) how y_plus, Cl and skin friction coefficient influence each other? i will be very thankfully if anyone answer there. i have attached photos of cl forum.jpg |
October 12, 2021, 20:02 |
#2 | |
If you really want to compare fluent vs SU2 (which I think they will give you a very very similar accurate RANS result at the end), pick a standard test case and dive deep into details starting from a coarse, medium and fine meshes. Showing, your solutions get closer and closer to the exact let's say value, and solutions show asymptotic behavior. They don't depend on the way you did discretize domains. You can even start from a 2D or a 3D standard test case and then do the similar study for your aircraft configuration. Over estimation of C_l max for a full aircraft configuration in RANS solution doesn't depend on specificity of solvers. It is a physical phenomena that needs to be really studied in a proper way. Good luck,
since every contribution counts, always good ones are appreciated! |
October 13, 2021, 01:07 |
#3 | |
charan
Rep Power: 5 |
so as you said if it is a courser mesh refining the mesh also influence fluent results?? ( i will refine and run the cases)forum_1.png and does mesh requirement for SU2 is different for fluent?? and i observed a different in y plus predicted by SU2 & fluent. |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
