Home > Forums > Software User Forums > SU2
How SU2 uses multi-node parallel computation
Like Tree1Likes
  • 1 Post By TKatt
Old   October 9, 2021, 05:35
Post How SU2 uses multi-node parallel computation
HuiLi
1qaz!QAZ is on a distinguished road
Hello all!
Can anyone knows how to write the command when SU2 adopts multi-node parallel computing ?
Thank you very much!
1qaz!QAZ is offline   Reply With Quote
Old   October 14, 2021, 12:27
na
TKatt is on a distinguished road
I am not sure whether I understand the question correctly. I now assume you do not use hybrid-parallelization (i.e. MPI+openMP).
The distribution on different nodes on a cluster (I now assume you are on a cluster) is done by a scheduler (lsf, slurm, ...). So you only have to specify the number of processes like mpirun -n 100 SU2_CFD config.cfg and the rest happens to the will of the scheduler.
Let me know wheather that answers your question
Best, Tobi
PENGGEGE777 likes this.
TKatt is offline   Reply With Quote
Scaling of parallel computation? Solver/thread count combinations? tdof OpenFOAM 8 January 13, 2022 12:39
[Other] Parallel computation on cluster Hamedhoorijani OpenFOAM Installation 1 December 17, 2020 07:28
Parallel Build for SU2 on Ubuntu McAero SU2 11 October 28, 2018 18:53
SU2 Parallel Computation pdp.aero SU2 Installation 5 June 19, 2013 15:02
Parallel multi core error b.raj FLUENT 0 April 11, 2013 14:19
