Home > Forums > Software User Forums > SU2
Center of Pressure Output
Like Tree2Likes
  • 2 Post By pcg
Old   April 13, 2021, 00:50
Default Center of Pressure Output
Juan Salazar
saladbowl is on a distinguished road
I am a recent user of SU2 and I noticed that the center of pressure result in the forces_breakdown.dat file is rather awkward. I find the following line in the file for an airfoil simulation (2D):
Center of Pressure: X=0.300838Y+0.239842 m.
The relevant source code I found is in CFlowOutput.cpp (version 7.1.1 "Blackbird"). In earlier versions it is in output_structure.cpp
    /*--- Begin forces breakdown info. ---*/
    Breakdown_file << fixed;
    Breakdown_file << "\n" << "\n" <<"Forces breakdown:" << "\n" << "\n";
    if (nDim == 3) {
      su2double m = solver_container[FLOW_SOL]->GetTotal_CFz()/solver_container[FLOW_SOL]->GetTotal_CFx();
      su2double term = (Total_CoPz/m)-Total_CoPx;
      if (term > 0) Breakdown_file << "Center of Pressure: X="  << 1/m <<"Z-"<< term << "." << "\n\n";
      else Breakdown_file << "Center of Pressure: X="  << 1/m <<"Z+"<< fabs(term);
      if (config->GetSystemMeasurements() == SI) Breakdown_file << " m." << "\n\n";
      else Breakdown_file << " in." << "\n\n";
    else {
      su2double m = solver_container[FLOW_SOL]->GetTotal_CFy()/solver_container[FLOW_SOL]->GetTotal_CFx();
      su2double term = (Total_CoPy/m)-Total_CoPx;
      if (term > 0) Breakdown_file << "Center of Pressure: X="  << 1/m <<"Y-"<< term << "." << "\n\n";
      else Breakdown_file << "Center of Pressure: X="  << 1/m <<"Y+"<< fabs(term);
The way it is being written, it looks like an equation. What am I missing here?
saladbowl is offline   Reply With Quote
Old   April 13, 2021, 05:41
pcg
Pedro Gomes
pcg is on a distinguished road
You are not missing anything, it is the equation for a line.
It is discussed here https://github.com/su2code/SU2/discussions/1227
(you'll need to scroll down a bit)
saladbowl and ugurtan666 like this.
pcg is offline   Reply With Quote
center of pressure, forces_breakdown, output, su2
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow pyccknn FLUENT 2 December 1, 2021 18:31
How is total pressure calculated? looee CFX 15 October 30, 2019 09:14
Reference point for calculating center of pressure krihamm CFX 1 January 31, 2018 05:36
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
