How to set up freestream turbulence conditions in incompressible solver |
Rep Power: 13 ![]() |
I found the following solution works thanks to pcg. Hope this is helpful.
% Freestream turbulence intensity value (default 0.05), activated for SST only FREESTREAM_TURBULENCEINTENSITY=0.01 % % Freestream nut / nu (default 10), activated for SST only FREESTREAM_TURB2LAMVISCRATIO=215.56 % % Freestream nu_tilde / nu (default 3), activated for SA only FREESTREAM_NU_FACTOR=215.568 --- % Original post as follows Hi everyone, I am running the incompressible RANS solver on a linear compressor cascade case (M=0.12, Rec=3.82*10^5). I tried to feed in the eddy viscosity ratio and the turbulence intensity in the configure file (see attached) as follows: FREESTREAM_TURBULENCEINTENSITY=0.01 FREESTREAM_TURB2LAMVISCRATIO=215.56 However, these values seemed not readed in, and I got nut/nu=0.20 in the freestream (see fig attached). I checked some archived tutorial cases. It seems to me the above options are activated only for compressible RANS solver, but I am not sure if that is true and why it is implemented in this way. Do you have any ideas? Cheers, Xiao Last edited by hx293; August 13, 2020 at 07:16. |
Pedro Gomes
Looking at the code it seems you should use FREESTREAM_NU_FACTOR
The two options you tried seem to be applicable only to k-omega models. P.S. In principle there are no differences between compressible and incompressible solver, so far as turbulence models go. Last edited by pcg; August 13, 2020 at 06:03. Reason: more info |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Question about matching of solver and turbulence model | louistse | OpenFOAM Running, Solving & CFD | 1 | February 1, 2017 21:36 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
