Home > Forums > Software User Forums > SU2
Сone flow simulation
Like Tree1Likes
  • 1 Post By aero_amit
Old   July 23, 2020, 14:49
Default Сone flow simulation
Pavel
pvlshilin is on a distinguished road
Hello, there!
I'm new to SU2. I was very interested in this software product, it is interesting to learn more about it. Before that, I worked only in ANSYS Fluent. I looked at test examples from the textbook, most of them are written for subsonic speeds.
I wanted to reproduce supersonic flow in the cone flow task. The type of problem is flat, axisymmetric. I built the geometry and selected the .cfg file from the available examples. To verify the results of the solution, I built the geometry in ANSYS Fluent.
The flow pattern was similar. However, the Mach cone angle doesn’t correspond to that obtained in ANSYS. Also, the value of surface parameters (pressure and temperature) was almost twice as high. The parameters in the area are also high.
I'm asking for your help in understanding the situation and pointing out my mistakes. In the app, I attach a grid file and a configuration file.
Thanks.
File Type: txt geo.txt (751 Bytes, 3 views)
pvlshilin is offline   Reply With Quote
Old   July 27, 2020, 01:57
Amit
aero_amit is on a distinguished road
Few suggestions -
Since you are trying to simulate flow past a cone, add
AXISYMMETRIC=YES in your .cfg file. Also you are running a second order accurate simulation by using MUSCL=YES, switch on the limiter by SLOPE_LIMITER_FLOW=VENKATAKRISHNAN_WANG.
Hope these should sort out the problems.
atelcikti1 likes this.
aero_amit is offline   Reply With Quote
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Numerical simulation of DBD plasma actuator induced flow mukut OpenFOAM 5 January 7, 2014 06:30
Convergence of jet flow simulation MiraLisa FLUENT 0 August 15, 2013 05:44
Coupling of drying process and flow simulation franzdrs Main CFD Forum 0 April 29, 2013 15:11
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
