July 22, 2020, 12:06 |
Wind turbine/Propeller simulations
Peter
Rep Power: 7 |
Can someone explain me why all wind turbine/propeller simulation uses a rotating frame (GRID_MOVEMENT)? Isn't it possible just to use the SURFACE_MOVEMENT setting for the blade surface? Regards, |
July 22, 2020, 15:06 |
Pedro Gomes
Rep Power: 14 |
You can use the SURFACE_MOVEMENT if the turbine is not rotating (sorry... had to go for it).
To simulate a rotating thing without actually rotating it you need a moving reference frame to capture the effect of inertial forces. Imposing just surface velocity is not enough, the fluid away from the walls is also subject to forces due to the rotation. |
Simulation of Wind Turbine with OpenFoam | be_inspired | OpenFOAM | 52 | September 6, 2018 11:33 |
Openfoam - Run Wind Simulations in Different Direction | YK123 | OpenFOAM | 3 | May 16, 2016 08:38 |
Software for Wind Field Simulation based on LiDAR data around Wind Turbines | davidebner | Main CFD Forum | 1 | July 19, 2015 23:28 |
Turbulence intensity - cross wind on a body | Fabio88 | Main CFD Forum | 0 | May 4, 2015 04:44 |
wind tunnel results vs fluent | pixie | Main CFD Forum | 1 | August 20, 2009 09:02 |
