May 29, 2020, 04:44 |
Numerical method for gradient calculation
Peter
Rep Power: 7 |
Are Green Gauss and Weighted Least Squares schemes node or cell based in SU2? Which would you use for a considerably skewed structural mesh with boundary layers? Green Gauss is better for high aspect ration cells like in the boundary layer, while Weighted Least Squares are performing better on bad meshes, right? Syrakos, Alexandros, et al. "A critical analysis of some popular methods for the discretisation of the gradient operator in finite volume methods." Physics of Fluids 29.12 (2017): 127103. Thanks, |
May 29, 2020, 06:07 |
Pedro Gomes
Rep Power: 14 |
I use Green-Gauss because it is faster.
WLS is purely node based. GG requires the values at the faces to be integrated, face values are obtained from averaging the solution at the nodes (SU2 uses a median dual grid, so the faces of the dual control volumes are always halfway between nodes). |
Reference for Convective numerical method: AUSMPLUSUP, AUSMPLUSUP2 | dhxlxz | SU2 | 2 | June 17, 2019 22:17 |
Numerical calculation of Cl, Cd, Cm from Cf and Cp | mmisu | Main CFD Forum | 6 | April 7, 2014 02:18 |
3D numerical flow calculation in steam turbine stage | mesik | FLUENT | 0 | March 24, 2014 15:35 |
Numerical calculation of fractional derivatives | Hamid Karani | Main CFD Forum | 1 | September 30, 2008 06:51 |
Solid-Liquid Two Phase Flow Numerical Simulation with the Finite Element Method | Qing Hao | Main CFD Forum | 2 | January 9, 1999 00:31 |
