Home > Forums > Software User Forums > SU2
Import salome mesh to SU2
Like Tree1Likes
  • 1 Post By giovanni.medici
Old   May 4, 2020, 04:44
Thumbs down Import salome mesh to SU2
Andrzej Świtała
pl96andy is on a distinguished road
Hi all
I'm new to cfd. I'm trying to import triangle mesh generated in salome 9.4 to SU2 7.0.4 using cgns format.
I export cgns HDF5 format to ADF using cgns tools obtained from debian packages.
While trying to run simulation i receive an error " Unsupported or unknown CGNS element type : (type6) "
What should i do about it?
Thany You
Andrzej
pl96andy is offline   Reply With Quote
Old   May 7, 2020, 11:48
Giovanni Medici
giovanni.medici is on a distinguished road
Hi pl96andy,
I've been trying to read in SU2 a CGNS mesh file created in Salome, in the past, but never succeeded, possibly with the new Salome and SU2 versions, is finally possible, if you managed to read a CGNS mesh in SU2 please let us know!!
As a backup solution I modified a script that was available so to export the native su2 file format. The problem is that the su2 files are ASCII, so they will be considerably less efficient than (binary) CGNS.
To load the script in Salome you have to ctrl+T and open the python script. Then simply type the command:
ExportSU2File("Mesh1","OutputMesh",["GroupToInclude1","GroupToInclude2"],["GroupToExclude"])
  • Mesh1 is the name of the mesh in Salome that you want to export
  • OutputMesh is the name of the output file that will be created, (with an .su2 extension)
  • GroupToIncluden is the name of the groups you want to export (usually Input, Output, Symmetry, Body ...) You must create group of faces of the boundaries of your interest otherwise you will export only the volume mesh. To create groups in Salome: Create Group --> select Edges ... (if 2D mesh), Faces ... (if 3D mesh), choose a name of the group, pick select from geometry, and select the conveniente faces in the geometry file. If you don't see any, you shall go back to the Geometry module and explode the geometry which contains the mesh.
  • GroupToExclude groups that you don't want to add to your mesh
I'll redirect you to the post where I was sharing the modified python script.
Salome cgns format mesh to SU2
bkay likes this.
giovanni.medici is offline   Reply With Quote
Old   June 10, 2020, 07:15
Andrzej Świtała
Hi giovanni.medici
Thank you for solution and explanation. Until some point it looks like mesh is accepted by SU2 but it freezes at "geometry preprocessing (zone 0)". Processor is fully loaded but after day nothing changes. The same is for mesh exported through gmsh.
To 'shorten' waiting time i runned calculations using parallel_computation.py
After some attempts i created new config file to make sure that all functions are for the same version of SU2. But it didn't changed anything.
Am i missing something?
Old   June 19, 2020, 06:25
Giovanni Medici
I just opened your output.txt file, and I think that your SU2 failed to include parallel computation when compiling.
I suggest you to recompile and/or check you have installed all dependencies.
The output of parallel_computation.py shall be a readable log, similar to the one produced when only one core is used.
Old   June 19, 2020, 09:31
Post
Andrzej Świtała
I've runned this simulation also on single core and output freezes in the same place. I'm using precompiled binary (without mpi in package name) so i weren't compiling anything...
While running tutorial cases, there wasn't problem with running in parallel. Also if this is needed i've installed mpich from debian stretch repository but i don't know how to use it .
Should i try to compile SU2?
Old   June 20, 2020, 03:50
Giovanni Medici
If you downloaded the precompiled binary without mpi, it won’t use all your cores, parallel_computation.py will not crash, but you will not take advantage of the speedup of parallelization. So if you plan to use the parallel feature I suggest you to download, install or compile the mpi version.
Going back to the mesh problem, how did you created the ”test_1.su2” mesh? I'm the .su2 is an ASCII file, so you can open it with a text editor to see if everything is as expected.
It shall more resamble the file format described here.
Old   August 4, 2020, 10:46
Andrzej Świtała
Mesh i've created in salome and exported it with python script.
I've recreated mesh to have some quadriangles.
i looked at exported mesh and mesh element 9 (according to website quadriangle element) occurs however there are some "None" elements. "9" elements have 5 columns of conectivity while "None" has 9 columns. That looks suspicious.
also i've tryied to export the same mesh to .med format, open it with gmsh and then export it to .su2. Simulation changs in the same moment however there are some "22" and "23" elements with 9 columns of conectivity.
I've tryied little with openfoam and also had problems with exported files from salome. In this case helped script to export directly from salome to openfoam.
I don't know how to do check this but maybe salome changed the way of exporting meshes.
cgns file read, mesh 2d, salome, su2
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
Best mesh generator compatible with SU2 JPBLourenco SU2 1 July 1, 2017 09:19
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 03:22
