Peter
Rep Power: 7 ![]() |
I am wondering if anybody tried to use the shroud marker as boundary condition. Can anybody explain me how to use it? What is the difference compared to Euler? Code:
------------------------------------------------------------------------- | ___ _ _ ___ | | / __| | | |_ ) Release 7.0.3 "Blackbird" | | \__ \ |_| |/ / | | |___/\___//___| Suite (Computational Fluid Dynamics Code) | | | ------------------------------------------------------------------------- | SU2 Project Website: https://su2code.github.io | . . . -------------------- Output Information ( Zone 0 ) ---------------------- Writing solution files every 1000 iterations. Writing the convergence history file every 1 inner iterations. Writing the screen convergence history every 1 inner iterations. The tabular file format is Tecplot (.dat). Convergence history file name: history. Forces breakdown file name: forces_breakdown.dat. Surface file name: surface_flow. Volume file name: flow. Restart file name: restart_flow.dat. ------------- Config File Boundary Information ( Zone 0 ) --------------- +-----------------------------------------------------------------------+ | Marker Type| Marker Name| +-----------------------------------------------------------------------+ | Euler wall| DUMMY_DOWN| | | DUMMY_UP| +-----------------------------------------------------------------------+ | Far-field| FF| | | IN| +-----------------------------------------------------------------------+ | Periodic boundary| SIDE-| | | SIDE+| +-----------------------------------------------------------------------+ | Outlet boundary| OUT| +-----------------------------------------------------------------------+ | Heat flux wall| BLADE| | | TIP| | | HUB| +-----------------------------------------------------------------------+ -------------------- Output Preprocessing ( Zone 0 ) -------------------- Screen output fields: INNER_ITER, RMS_DENSITY, RMS_MOMENTUM-X, RMS_MOMENTUM-Y, RMS_ENERGY History output group(s): ITER, RMS_RES Convergence field(s): REL_RMS_DENSITY Ignoring Time Convergence Field(s): TAVG_DRAG Warning: No (valid) fields chosen for time convergence monitoring. Time convergence monitoring inactive. Volume output fields: COORDINATES, SOLUTION, PRIMITIVE ------------------- Geometry Preprocessing ( Zone 0 ) ------------------- Three dimensional problem. 1017064 grid points. 2432720 volume elements. 11 surface markers. 27860 boundary elements in index 0 (Marker = BLADE). 67158 boundary elements in index 1 (Marker = DUCT). Error in "short unsigned int CConfig::GetMarker_CfgFile_TagBound(std::__cxx11::string)": ------------------------------------------------------------------------- The configuration file doesn't have any definition for marker DUCT Code:
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker) % Format: ( marker name, constant heat flux (J/m^2), ... ) MARKER_HEATFLUX= ( BLADE, 0, TIP, 0, HUB, 0 ) % % Euler wall boundary marker(s) (NONE = no marker) MARKER_EULER= ( DUMMY_DOWN, DUMMY_UP) % MARKER_SHROUD= (DUCT) % Far-field boundary marker(s) (NONE = no marker) MARKER_FAR= ( FF, IN) % INLET_TYPE= TOTAL_CONDITIONS % MARKER_INLET = (IN, 288.15 , 101325.0, 1.0, 0.0, 0.0) % % Outlet boundary marker(s) (NONE = no marker) % Format: ( outlet marker, back pressure (static), ... ) MARKER_OUTLET= ( OUT, 101325.0 ) % % Periodic boundary marker(s) (NONE = no marker) % Format: ( periodic marker, donor marker, rotation_center_x, rotation_center_y, % rotation_center_z, rotation_angle_x-axis, rotation_angle_y-axis, % rotation_angle_z-axis, translation_x, translation_y, translation_z, ... ) MARKER_PERIODIC= ( SIDE-, SIDE+, 0 0 0, 72 0 0, 0 0 0) Peter |
Pedro Gomes
Rep Power: 13 ![]() |
I've not used this myself, but looking at the code I think the purpose of that marker it to specify a stationary shroud (in an otherwise rotating domain).
It is not a boundary condition by itself, you still need to have a Euler/Heatflux/Isothermal boundary condition for that marker. |
