Home > Forums > Software User Forums > SU2
output file error v7.0.3
Like Tree1Likes
  • 1 Post By talbring
Old   April 3, 2020, 09:19
Default output file error v7.0.3
jcownbey is on a distinguished road
Why am I continuing to see this error, 'error finishing tecplot file output"? I do not know if it affects my results or not, but I would like to understand why it is there.
------------------------- Solution Postprocessing -----------------------
Reading and storing the solution from restart_flow_3.
Volume output fields: COORDINATES, SOLUTION
|Tecplot |flow2.szplt |
|Tecplot surface |surface_flow.szplt |
Internal error: getZoneHeaderFilePosition() called before writeZone()....aborting.
0: Error finishing Tecplot file output.
jcownbey is offline   Reply With Quote
Old   April 4, 2020, 08:56
Tim Albring
talbring is on a distinguished road
This error is printed if SURFACE_TECPLOT is in the OUTPUT_FILES option but there is no marker set with MARKER_PLOTTING. It should not affect your results in any way.
jcownbey likes this.
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
error
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
