Home > Forums > Software User Forums > SU2
Explicit finite difference formula
Like Tree1Likes
  • 1 Post By pcg
Old   April 2, 2020, 22:48
Default Explicit finite difference formula
Marrie
manle0312 is on a distinguished road
I am a new user of SU2. After playing with the code, I decide to dig deeper to understand how things are put together. I am running the tutorial on the Inviscid Bump using an Euler implicit schems for time discretization and JST to handle convective flux. In the SU2_CFD folder, there are lots of subroutines that are use to do a lot of things: numerics, integrations... The SU2_CFD seems to do all of the function calls to these different functions. Usually in my CFD class, we have a final step to advance the solution to the next time. Where can I find this?
manle0312 is offline   Reply With Quote
Old   April 3, 2020, 05:22
pcg
Pedro Gomes
pcg is on a distinguished road
In CIntegration::Space_Integration you see the calls to the CSolver methods responsible for spacial integration e.g. the application of the convective scheme.
In CIntegration::Time_Integration you see the calls to the different methods of advancing the solution in time (or pseudo-time for dual-timestepping).
You can then look, for example, in CEulerSolver::ImplicitEuler_Iteration to see the implementation.
(we have been moving and renaming the files and I am not sure what version you are using, in any case if you look for those names in .cpp files it should be fine)
manle0312 likes this.
pcg is offline   Reply With Quote
Finite difference method kaliramesh FLUENT 1 January 16, 2014 13:55
need an overview on all the finite difference schemes mihaipruna Main CFD Forum 3 December 13, 2013 04:00
Control volume based finite difference method? mukut.medhi Main CFD Forum 3 August 24, 2012 11:01
Finite Difference Vs. Finite Volume elankov Main CFD Forum 43 December 18, 2010 17:30
Equations for finite difference, element & volume W.L.C. Main CFD Forum 9 April 3, 2001 13:08
