February 24, 2020, 09:03 |
Roe upwind scheme
SALERNO
Rep Power: 6 |
Hi everyone, I am trying to computing some aerodynamic coefficients (drag, lift, coefficient of pressure) using the Roe upwind scheme, but it doesn't converge. I tried also to use the multigrid method, but I had no success. Are there any options that might I have missed in my .cfg file?
wingD.txt |
February 24, 2020, 12:12 |
Amit
Rep Power: 13 |
Can you share the cfg file. Multigrid with Roe does not work well in SU2 (usually JST goes well) .
February 25, 2020, 15:55 |
SALERNO
Rep Power: 6 |
Hi aero_amit, I have shared the cfg file yet (it is the txt file named wingD). I must use Roe scheme for "academic issues", is there a way to reach convergence?
February 26, 2020, 06:09 |
Pedro Gomes
Rep Power: 13 |
In my experience the multigrid works very well in hex-dominant grids, provided you are not using too many cores relative to problem size (see pull request 861 on GitHub)
My advice (based on RANS cases): Use only pre-smoothing (1, 1, 2, 3), 2-3 levels should be enough. 0.7 damping coefficients. Limiters tend to make the case flip flop, Venkatakrishnan-Wang works best but try using no limiter (your case is subsonic). If you really want limiters, increasing the Venkat coefficient may help. Fixed CFL in the range 15-25, going higher sometimes makes convergence harder. Increase the entropy fix factor until you get convergence, then worry about its influence on the solution (once you have a converged solution for initialization it is easier to converge with lower fix factors). FGMRES + LU-SGS, no more than 10 linear iterations and tolerance of 0.05 or so should be more than enough, especially on inviscid grids. I stay away from the low-Mach schemes / options, you can probably do without them too at Mach 0.2. |
February 26, 2020, 09:14 |
SALERNO
Rep Power: 6 |
Hi pcg, my case is an Euler one, with a low Mach (0.2). Is your advice still valid for my situation?
I have another (maybe stupid) question: I have ever studied finite difference methods right now, and for upwind schemes the CFL condition is less or equal than 1. I noticed that either in SU2 tutorial or in the other threads the suggestions take in consideration CFL numbers of 10/20/30 and so on...are the upwind schemes (like Roe's scheme, for example) still stable at such a high CFL number? I have started using SU2 and finite volume method since a very little time, so I ignore a lot of things! :S |
February 27, 2020, 03:24 |
Pedro Gomes
Rep Power: 13 |
I would say it is worth a shot.
The CFL limit depends on the (pseudo)time integration method, for explicit Euler (the integration, not the equations) it is very low like you say, Runge-Kutta methods allow slightly higher values, and implicit Euler is unconditionally stable (but the implicit part is based on an approximate linearization of the residual so there are practical limits). |
February 27, 2020, 05:07 |
SALERNO
Rep Power: 6 |
That's right, but there is a thing that I can't understand: I have two grids, a coarse one and a finer one; if I try to do the computation on the coarser grid it converges, but if I use the same options on the finer one, it does not converge. Which could be the reason?
bounded Gauss upwind Scheme | deepinheart | OpenFOAM Running, Solving & CFD | 1 | February 23, 2015 05:57 |
Implementation of 2nd order upwind scheme | jaason | OpenFOAM Running, Solving & CFD | 4 | February 6, 2015 17:40 |
2nd order upwind vs 2nd order upwind!!! | Far | Main CFD Forum | 7 | March 14, 2013 12:29 |
Use of upwind scheme for interpolation of u/v | quarkz | Main CFD Forum | 6 | August 30, 2011 04:10 |
2nd order upwind scheme (Fluent and CFX) | Far | FLUENT | 0 | May 22, 2011 01:50 |
