Home > Forums > Software User Forums > SU2
Moving Wall condition
Like Tree2Likes
  • 1 Post By hk.narahari
  • 1 Post By jdp810
Old   September 28, 2019, 03:24
Default Moving Wall condition
Dr. H.K. Narahari
hk.narahari is on a distinguished road
I was wondering if we could use 'Moving_Wall' option under Dynamic Mesh to simulate ground effect? Would that be appropriate or in-consistent wit SU2 formulation ?
Thanks
Narahari
REJISH likes this.
hk.narahari is offline   Reply With Quote
Old   November 10, 2021, 06:26
REJISH
REJISH is on a distinguished road
Hi Dr. H.K. Narahari,
I am also interested in simulating ground effect using SU2.
Did you find a way to solve your problem?
It would be very helpful if you give me direction regarding this.
REJISH is offline   Reply With Quote
Old   November 12, 2021, 02:51
Jose Daniel
jdp810 is on a distinguished road
I use this config file to simulate ground effect. This is an example of a 3D aircraft flying straight at X meters from the runway with a pitch of -3 deg. The mesh is built so that the bottom boundary condition is tilted 3 deg in the y axis.
A similar effect can be achieved with the model of the aircraft rotated -3 deg and setting the AOA = 0, but I did it the other way for other reasons.
For the ground boundary conditions I chose a symmetry bc because I don't care about temperature and as an Euler simulation, both Euler wall and symmetry are the same. If your simulation is RANS, use the heatflux wall boundary condition.
Hope this helps,
JD
REJISH likes this.
jdp810 is offline   Reply With Quote
Old   November 12, 2021, 06:32
REJISH
Hi JD,
Thank you very much for the file.
Why don't you specify your ground (Euler-wall) as moving wall boundary condition and specify velocity of the wall to capture the ground effect?
Best regards,
Rejish
Old   November 12, 2021, 07:26
Jose Daniel
In an Euler simulation, both moving and regular wall will be the same as the wall condition is no penetration, not velocity = 0
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 12:30
Use of moving wall in COMSOL? MultiPhy COMSOL 1 September 24, 2018 19:39
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Deal with wall boundary with moving mesh by FVM? aiya Main CFD Forum 6 May 10, 2007 12:33
Deformation of wall by temperature condition Jay FLUENT 0 April 14, 2007 19:06
