Home > Forums > Software User Forums > SU2
Log printed history of solution
Like Tree1Likes
  • 1 Post By aero_amit
Old   July 25, 2019, 08:08
Default Log printed history of solution
Shubham jhamb
Shubham_J is on a distinguished road
Hey!
I am new to SU2. I am analyzing supersonic flow across an airfoil. For post-processing, I need to log the real-time solution data that is printed on the screen. What command do I give?
For eg. for running the SU2 simulation, command:
SU2_CFD config.cfg
For logging the solution, command:
(I suspect it is of the form SU2_CFD>history.log). But I am not sure.
The printed history is -> https://www.dropbox.com/s/n78j7d9y12...04-58.png?dl=0
Thanks in advance.
Shubham_J is offline   Reply With Quote
Old   July 25, 2019, 10:04
Amit
aero_amit is on a distinguished road
SU2_CFD config.cfg>history.log
will do the job.
You can add & in the end, which will run it in the background.
nohup SU2_CFD config.cfg>history.log &
Use tail -f history.log to print it in terminal.
Best
Amit
Shubham_J likes this.
aero_amit is offline   Reply With Quote
Old   July 25, 2019, 10:29
Shubham jhamb
Thanks! It works perfectly
Converging the solution aja1345 FLUENT 13 June 15, 2022 00:46
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
