Use coarse grid flow solution as initial solution for fine grid |
Nathan Ricks
Rep Power: 11 ![]() |
Hi SU2 Users,
I think the title is pretty self-explanatory, but I will expand for clarity. I'm just wondering if it is possible to use a flow solution from a coarse grid, as the initial solution for running a finer resolution grid of the same geometry? So if there is some sort of built-in interpolation between two meshes? I'm running a case where if the solution does not converge, I refine the mesh, and run again on the refined mesh - so it would be great if I could use the flow solution obtained from the coarse mesh (as long as it didn't diverged, just didn't converge in a set number of iterations) as a starting point for the fine grid. If you know if this sort of thing is available, please let me know! Thank you in advance, Kind Regards, Nathan |
Pedro Gomes
Rep Power: 13 ![]() |
Hi Nathan,
Currently that functionality is not implemented, but someone is working on it for v7. Cheers, Pedro |
Nathan Ricks
Giovanni Medici
Rep Power: 12 ![]() |
I know it is a relatively old post, anyway I was wondering whether the function
of interpolating a solution of a coarse mesh onto a refined one, is actually available in the latest SU2 versions (7.5.0). I know that a lot of effort was carried out in the last years and releases, and that until say version 7.0.3 a feature_adap branch was carrying that option (it was actually providing a lot more, with mesh adaptation based on solution parameters). To my understanding that branch didn't make it to merge to the master one, and is not updated. Thanks! |
Pedro Gomes
It is currently possible to restart from a solution on a coarser (or finer) mesh.
No options are required. |
Giovanni Medici
Oh, that's great, thanks for the answer Pedro!
Hyun Ko
Rep Power: 17 ![]() |
grid refinement, interpolation, restart solution, su2 |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 17:45 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
