Unstaedy Simulation of ramp up motion of airfoil in su2 |
Vivek.S
Rep Power: 0 ![]() |
How to carry out unsteady ramp up maneuver (angle of attack increasing from 0 to 20 degrees linearly in time) in su2.Is there any option to do so in the configuration file? |
na
Rep Power: 8 ![]() |
you might take a look at 'TestCases/unsteady/pitching_{euler/RANS}' in the code. This is a continuous pitching of an airfoil with rigid mesh rotation. You might want to adapt the angle and "rotation speed" Omega to your needs. Together with suitable End-time you can simulate just your linear ramping part. Hope that help, Tobi Edit: I just saw this issue on github https://github.com/su2code/SU2/issues/644 which is related to your question and might help if you think about going into the code a bit |
Need help for the 2D airfoil simulation using OpenFoam | losiola | OpenFOAM Running, Solving & CFD | 0 | October 10, 2018 10:22 |
SU2 python scipt runs in parallel but repeats the simulation | topheruk29 | SU2 | 1 | August 13, 2018 18:01 |
Ahmed body simulation gives unexpected results in su2 6.0 | anas651 | SU2 | 0 | March 28, 2018 03:42 |
Trying to perform test validity of Fluent with simulation of 2D airfoil | didiean | FLUENT | 39 | December 5, 2015 13:31 |
Simulation of DU 97 W 300 2D Airfoil | daniele.arloti | FLUENT | 0 | December 2, 2015 06:25 |
