January 31, 2019, 05:44 |
time variable grid movement
I have to do a 2D unsteady RANS simulation of a NACA0012 profile with variable pitching angle over time. My problem is, that my inputsignal of the pitching angle is time variable and not continous and i havo no clue how to implement it in the SU2 code. Is it possible at all to realize a timevariable inputsignal of the motion of the airfoilstructure?
February 11, 2019, 01:57 |
Anjay
Rep Power: 7 |
Hey Neumy,
By time variable, do you mean that the change in pitch angle changes with time? If the change of angle is constant with time, the required options are given in the config_template file. Anjay |
February 13, 2019, 09:09 |
Hey Anjay,
Thank you for your answer. I meant that the change in pitch angle is not constant with time. It shall be a specific signal, witch is created by myself. According to SU2 it is not possible to implement a time variable input signal in the config file. But I've managed it by customizing the python code of the py_wrapper test case flatPlate_rigidMotion. There it is possible to implement the input signal of the wing movement. |
su2, variable pitching angle |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
