Home > Forums > Software User Forums > SU2
SU2_CFD 3d euler not converge mine gmsh mesh
Like Tree1Likes
  • 1 Post By akoodlyr
Old   November 30, 2017, 10:46
Default SU2_CFD 3d euler not converge mine gmsh mesh
Luca
lpustin is on a distinguished road
Hello all,
I'm an aeronautical engineering student and I'm new to CFD,
I want to do CFD analysis with my own mesh generated with gmsh.
I converted it in su2 mesh file and I utilize the same configuration file of inviscid onera m6 wing. Only difference in configuration file are markers: I utilize only one marker 'WING' for all the wing surface instead of ' UPPER_SIDE, LOWER_SIDE, TIP'.
I use NACA 0012 profile for tip and root, chord 0.5 m for tip and root and 1 m and 2 m of span my tip is closed with a plane surface (marked WING also).
I attach photos my mesh
prolile_detail_2.jpg)
It is made by 2 millions elements, the mesh is more fine near tip and leading edge.
Distance and characteristic length from far field are similar to the onerama m6 provided mesh.
Hope somebody could help me,
I attach config file, photos of my mesh, my geo gmsh file, and SU2_CDF log files.
wing_geo.txt
configuration_file_cfg.txt
log_CFD.txt
The attached configuration files work with the provided onera m6 mesh and didn't works with mine, I've tried also at mach 0.3.
Thanks a lot.
lpustin is offline   Reply With Quote
Old   December 1, 2017, 14:11
Akshay Koodly
akoodlyr is on a distinguished road
Can you try with the multigrid turned off? (In the cfg file, set MGLEVEL=0). We worked on 3-d wings earlier and it took us a few trials to get the multigrid parameters right and experienced similar blow-ups with the 'wrong' parameters. Maybe the settings you are using is the problem. You can also try experimenting with different multigrid settings to get it right.
Here is an older thread where it is explained in more detail
Multigrid parameters
lpustin likes this.
akoodlyr is offline   Reply With Quote
Old   December 3, 2017, 14:43
Default solved
Luca
Thank you akoodlyr for your post,
I've tried with multigrid off but it diverge anyway.
My problem is that I utilize a program gmsh2su2 to convert my .msh grid into .su2 grid.
The SU2_DEF works correctly but not SU_CFD.
Now exporting in .su2 directly by gmsh all works fine also the optimization using shape_optimization.py works fine.
I'm very happy using su2.
diverge, euler
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
Dont find the converge in NACA0012 with structured mesh ynos OpenFOAM Running, Solving & CFD 2 December 14, 2013 07:03
