October 25, 2017, 06:37 |
Fluid-Structure Interaction with SU2
Rep Power: 11 |
EDIT: some *.cfg files for FSI problems available online at: https://github.com/su2code/SU2/tree/master/TestCases
Hi all, I am new to SU2 and would like to perform some FSI studies. Based on the most recent publications there seems to be an FSI implementation in SU2. I wasn't able to find much about it and was curious if any of yous has done it already? |
November 4, 2017, 10:39 |
#2 | |
Mehdi Mortazawy
Rep Power: 9 |
Hello Raz, In the latest version, you can find some tutorials in the test-case/ interface folder(.cfg files) if I am correct. Their corresponding mesh should exist in a separate master testcase also on github. Cheers, Mehdi |
December 12, 2017, 19:06 |
Rep Power: 10 |
You can also do FSI by coupling SU2 with CalculiX or other solvers using preCICE. All of these tools are free software.
Here is a tutorial: https://github.com/precice/precice/wiki/FSI-tutorial |
cfd, fea, fsi, su2 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 14:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | ANSYS | 0 | July 22, 2016 14:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 14:39 |
About one-way Fluid-Structure Interaction, form structure to fluid !? | xq712000 | ANSYS | 0 | July 15, 2016 10:40 |
Fluid Structure Interaction using icoFsiFoam Problems | lr103476 | OpenFOAM Running, Solving & CFD | 79 | August 7, 2014 10:30 |
