Home > Forums > Software User Forums > SU2
Shock Capturing in SU2 (moving shock in a tube)
Like Tree1Likes
  • 1 Post By talbring
Old   October 6, 2017, 05:40
Post Shock Capturing in SU2 (moving shock in a tube)
Mehdi Mortazawy
mhd_mrt is on a distinguished road
Hello all,
I am trying to simulate a moving normal shock wave in a tube by specifying the pressure, temperature and velocity before and after the shock wave. For some reason my results aren.t perfect and I am wondering id it has to do with my boundary conditions or numerical dissipations or ...? The results should follow Anderson's Modern Compressible Flow, Chapter 6.
Below you can see my problem setup. I have a 2D rectangular mesh and I am running Unsteady Simulation, Dual Time Stepping, ROE scheme with Runge Kutta Explicit Time Discretization. Any comment or suggestion with regard to capturing this moving normal shock will be highly appreciated. My config and result are attached.
Thank you!
Mehdi
mhd_mrt is offline   Reply With Quote
Old   October 13, 2017, 17:12
Tim Albring
talbring is on a distinguished road
Hi Mehdi,
what exactly is your problem ? Do you get oscillations near the shock ? If so, try to reduce the value of LIMITER_COEFF in the config.
Tim
mhd_mrt likes this.
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Old   November 4, 2017, 09:49
Default Shock Capturing in SU2 (moving shock in a tube)
Mehdi Mortazawy
Hi talbring!
Thanks! Yeah I realized that LAX-FRIEDRICH is inherently very dissipative across shocks and the mesh resolution needs to be super refined in order for the solver to produce comparable results to either HLLC or ROE.
It also very well depends on the strength of the moving shock (=pressure ratio). I was running this for the extreme case of P2/P1 =10 which corresponds to even a higher P4/P1 ratio. Also the oscillations are occurring at such a short distance when considering the speed of the moving shock (W)
Thanks!
moving shock, shock, shock capturing, shock tube, su2
Simulation of moving normal shock wave ROHAN Main CFD Forum 1 May 22, 2016 04:14
Shock capturing in 2D/3D Abhishekd18 Main CFD Forum 2 June 27, 2014 12:42
MUSCL shock capturing on high aspect ratio meshes vijay_paul Main CFD Forum 1 September 29, 2012 01:16
Will compression waves overtake a moving shock? GRA Main CFD Forum 2 October 19, 2006 01:24
Shock capturing Dr B.M. Smith (Smith) OpenFOAM Running, Solving & CFD 1 December 10, 2004 06:40
