Home > Forums > Software User Forums > SU2
NASA's grids not working on SU2
Like Tree1Likes
  • 1 Post By gittagawa
Old   August 4, 2017, 09:22
Exclamation NASA's grids not working on SU2
gittagawa
gittagawa is on a distinguished road
Hello all,
I am new in CFD and I am running some simulations on a NACA 0012. I have used the configuration file from:
https://github.com/su2code/SU2/blob/...CA0012_sst.cfg
and the grid from:
https://github.com/su2code/TestCases.../rans/naca0012
The results are very close to NASA test cases'. However, when I try to use NASA's grids (from the link below), it does not work.
https://turbmodels.larc.nasa.gov/naca0012_grids.html
I changed the configuration file to use .CGNS:
% Mesh input file
MESH_FILENAME= n0012_113-33_hex.cgns
% Mesh input file format (SU2, CGNS, NETCDF_ASCII)
MESH_FORMAT= CGNS
Is there any difference between the grids provide by SU2 and by NASA? What else should I change?
I need to run some simulation in a different airfoil (NACA 4412). I can find the grid in NASA website but I end up with the same problem.
Can anyone help me, please?
Thank you very much!
gittagawa is offline   Reply With Quote
Old   August 7, 2017, 04:20
Alberto Pizarro
AlbertoPi is on a distinguished road
Maybe the grid is not appropriate. The markers of the boundaries and the thickness of the grid in the spanwise-direction can be wrong to SU2.
Do you have some error message?
The mesh of the TestCases folder is equivalent or you can try to use your own mesh.
Regards,
Alberto.
AlbertoPi is offline   Reply With Quote
Old   August 9, 2017, 19:17
Thumbs up Problem solved
gittagawa
I changed the markers and it worked. Thanks a lot Alberto!
AlbertoPi likes this.
Old   August 11, 2017, 09:46
Francisco Palacios
fpalacios is on a distinguished road
Thanks a lot for using SU2,
The problem with the CGNS format in the NASA webpage is that we are using a 3D grid for a 2D problem (not really very efficient). If you are going to use NASA grid... they are really good, my recommendation is to translate the plot3D to su2 format using the scripts that you can find in
https://github.com/su2code/MeshTools
inside the folder Python/
Best Regards,
Francisco
fpalacios is offline   Reply With Quote
Old   August 12, 2017, 20:41
gittagawa
I am using grids from NASA because I had to simulate the NACA 4412 airfoil. I think there is no grid available at SU2 repository, right? I found for the NACA 0012 only.
I will use script to convert it.
Thank your very much Francisco!
cgns, grid, nasa test cases, su2
Parallel execution of SU2 marco.fossati SU2 15 June 13, 2024 17:39
Official release of SU2 V3.0 and SU2 Educational V1.0 fpalacios SU2 News & Announcements 2 January 22, 2014 06:28
Incorrect calculation of forces/moments coefficients with older versions of SU2 diwakaranant SU2 2 August 16, 2013 05:17
SU2 suite has moved to GitHub! fpalacios SU2 News & Announcements 0 August 12, 2013 03:07
structured and unstructured grids user Main CFD Forum 6 November 25, 2010 02:14
