Osman Mirza Demircan
Rep Power: 9 ![]() |
Has anyone got a complete configuration file that they can share, which includes all of the options from the last update? The template on github is missing some elements and it's a bit of a tedious task to try to gather them all through searching all the test cases and the forums. Thank you, Osman Mirza Demircan |
Alberto Pizarro
Rep Power: 10 ![]() |
Check out:
http://su2.stanford.edu/doxygen/group___config.html You can found here all descriptions of the configuration options. Regards. |
This is very helpful, thank you!
Francisco Palacios
Rep Power: 15 ![]() |
Hi, thanks for using SU2,
I'm sure you are familiar with this but, just in case, remember that the file config_template.cfg (in the parent SU2 folder) is the master config file with all the options. Best, Francisco |
configuration, configuration file, su2, template, update |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
