Direct simulation converging but not the Adjoints |
September 23, 2016, 15:54 |
ANAND AMRIT
Hello everyone,
I am running a CRM wing case and is using EULER equation. My DIRECT simulation converges pretty well. However when it does ADJOINT simulation (continuous adjoints), it says there are some non physical points in the solution and the solution never converges, rather the residuals go very high. I have set MGLEVEL= 0, still its the same problem I have attached the figures plotting the residuals for both direct and adjoint simulations. Also the configuration file is attached. adjoint_simu.JPG direct_simu.JPG CRM.txt Thanks Anand |
November 17, 2016, 18:59 |
#2 | |
Heather Kline
Rep Power: 14 |
1. Greater convergence on the direct solution. The closer the residuals are to machine zero, the better. 2. Use the CFL_REDUCTION_ADJFLOW parameter to reduce the CFL value compared to what is used for the direct problem. 3. In order to turn of MG for the adjoint solution but still use it for the direct solution, use MG_ADJFLOW = NO 4. If the issue is that the mesh isn't great, try using RELAXATION_FACTOR_ADJFLOW (set to something slightly less than 1.0). 5. Try using a 1st-order method, at least to start up the solution (CONV_NUM_METHOD_ADJFLOW / SPATIAL_ORDER_ADJFLOW) |
TimeVaryingMappedFixedValue for Direct Numerical Simulation inlet | johndeas | OpenFOAM | 5 | May 21, 2014 08:11 |
Incompressible simulation | brugiere_olivier | SU2 | 2 | April 15, 2014 11:12 |
Simulation and Optimisation of centrifugal fan 3D to 2D | eRzBeNgEl | STAR-CCM+ | 0 | January 31, 2013 14:21 |
Dynamic mesh simulation not converging | mrestrepo30 | FLUENT | 0 | March 8, 2010 15:15 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
