August 11, 2016, 10:49 |
HEAT optimization
Tom
Rep Power: 10 |
Hi every one
I have a question regarding optimization How can I perform an heat transfer optimization within SU2? like I have an aerodynamic body which has high temperature on its nose because of its high velocity and I want to optimize the shape of the nose in order to reduce the temperature on the nose. how can I do that? there are two options in the config file for the objective function which seems to have sth with temperature (TOTAL_HEATFLUX, MAXIMUM_HEATFLUX). what are their diffrences ? How can I calculate mu flow simulation heat flux with su2? thanks alot |
August 16, 2016, 16:36 |
#2 | |
Heather Kline
Rep Power: 14 |
August 16, 2016, 19:57 |
heat flux
Tom
Rep Power: 10 |
thanks alot for your answer Heather Kline
but hoe can I compute the heat flux within SU2, so I can see the effect of opyimization? thanks alot |
August 17, 2016, 14:40 |
#4 | |
Heather Kline
Rep Power: 14 |
I also encourage you to try out the tutorials (if you have not already), which include examples of shape optimization: https://github.com/su2code/SU2/wiki/User-Tutorials |
Heat Release vs. Apparent Heat Release // Comparison with GT Power | MFGT | CONVERGE | 10 | August 17, 2016 02:38 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Heat Transfer mechanisms | tafaugl | CFX | 1 | November 7, 2012 18:46 |
Parametric runs and Optimization in ANSYS (Conjugate Heat Transfer Problem) | cp_jef | ANSYS | 0 | May 30, 2011 04:08 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
