Example of configuration file for GRAD_FLOW mesh adaptation |
August 1, 2016, 14:19 |
kowalski
Rep Power: 10 |
Hi all,
I would be grateful to the community if someone can point me to a tutorial / example on how to set up mesh adaptation based on flow features. There was a tutorial (#13) which apparently got removed. I was looking at the mesh_adaptation.py script but since I have no configuration file to start with it is not very useful. I am using the following settings (modified from those in the config_template.cfg) but my adaptation over a transonic rae2822 is not doing anything related to the flow field. % ------------------------- GRID ADAPTATION STRATEGY --------------------------% % % Kind of grid adaptation (NONE, PERIODIC, FULL, FULL_FLOW, GRAD_FLOW, % FULL_ADJOINT, GRAD_ADJOINT, GRAD_FLOW_ADJ, ROBUST, % FULL_LINEAR, COMPUTABLE, COMPUTABLE_ROBUST, % REMAINING, WAKE, SMOOTHING, SUPERSONIC_SHOCK) KIND_ADAPT= FULL_FLOW % % Percentage of new elements (% of the original number of elements) NEW_ELEMS= 5 % % Scale factor for the dual volume DUALVOL_POWER= 0.5 % % Adapt the boundary elements (NO, YES) ADAPT_BOUNDARY= YES Is there any other parameter I have to set in the config file that I am missing? Thanks Marco |
September 6, 2016, 09:41 |
Ignatius Yudki Utama
Hi Marco,
1. Do you have a restart flow input file? Have you set your restart flow input file option into your file (SOLUTION_FLOW_FILENAME)? 2. Have you set the "Restart solution" to be "yes" (RESTART_SOL= YES)? |
kind_adapt = grad_flow, mesh adaptation |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 15:30 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
