June 9, 2016, 15:11 |
Discrete adjoint surface_adjoint
Ryan Barrett
Rep Power: 11 |
I have noticed when using the discrete adjoint that the surface_adjoint gets two new columns, x_Sens and y_Sens. What are these? I thought they were the x and y components of the sensitivity, but the numbers don't seem to match up. For example one node has the following values -0.440, -0.128, and -0.448 for the Sensitivity, x_Sens, and y_Sens respectively. The magnitude of the vector assuming a x-component of -0.128 and a y-component of -0.448 would be 0.466, not the 0.440 that the Sensitivity says.
June 11, 2016, 12:20 |
Tim Albring
Rep Power: 10 |
Hi Ryan,
you are right, the x_Sens and y_Sens are the components in x and y direction, respectively. Note that Sensitivity represents the sensitivity in the direction of the surface normal and not the magnitude. Tim |
su2 |
The discrete adjoint method uses too large memory. | Yminjo | SU2 | 1 | April 27, 2016 10:52 |
Boundary Conditions Of Discrete Adjoint Method For 2D NS Equations | Ashkaari | Main CFD Forum | 4 | January 27, 2016 20:05 |
Discrete Adjoint Euler Computation | doan.nak | SU2 | 2 | June 6, 2014 04:01 |
Discrete Adjoint Optimization ? | Tommy Chen | SU2 Shape Design | 1 | March 5, 2013 14:08 |
A question about discrete adjoint method | Thomas | Main CFD Forum | 3 | August 9, 2006 12:37 |
