Home > Forums > Software User Forums > SU2
Global CFL Setup
Like Tree1Likes
  • 1 Post By hlk
Old   April 8, 2016, 05:25
Default Global CFL Setup
Paul Zhang
paulzhang is on a distinguished road
Is there a way to use a global CFL, ramping from a small value up to a user defined upper limit, without modifying the code?
I feel the a universal physical time step for each cell makes more sense than variant one.
Thanks,
Paul
paulzhang is offline   Reply With Quote
Old   April 11, 2016, 13:42
hlk
Heather Kline
hlk is on a distinguished road
Thanks,
Paul
For more information on the current CFL adaptation options see:
http://www.cfd-online.com/Forums/su2...parameter.html
As you can see in the cfd-online entry on the CFL number (http://www.cfd-online.com/Wiki/Coura...Lewy_condition), the CFL number is defined relative to the grid size and so a constant CFL will not necessarily give a constant time step across the mesh. If you would like to use constant time-stepping, you may want to use the unsteady capability. Some examples are in TestCases/unsteady, where you would need to change the UNSTEADY_SIMULATION setting to TIME_STEPPING to get the behavior that I think you are describing.
mlooti likes this.
hlk is offline   Reply With Quote
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
