February 16, 2016, 07:42 |
One about design variables
Tom
Rep Power: 11 |
Hello everyone a quick question
which module is responsible for making design variables to be the value of “DEFENITION_DV “ ? If would be great if one can give some explanations about how to pass some setting (like FFD or Hicks-Henne …) to that module and get the values needed for DEFENITION_DV I see in some pages that in the previous editions it was MDC Also which source file has the codes related to design variables Thanks alot Last edited by mlooti; February 16, 2016 at 08:54. |
February 16, 2016, 09:23 |
Tim Albring
Rep Power: 11 |
Hi Mohammad,
you can find more information on setting up a case using FFD in the wiki: https://github.com/su2code/SU2/wiki/...f-a-Fixed-Wing Tim |
February 16, 2016, 12:32 |
Tom
Rep Power: 11 |
Tanks Tim
I have read that tutorial complicity and I know about that python script which is mentioned there but mainly I want to know about Bump functions like HICKS_HENNE, COSINE_BUMP, SPHERICAL, NACA_4DIGITS ….. I check out the DEF module which I think is responsible for mesh deformation, I want to know how I can generate the DEFINITION_DV of these functions automatically |
February 23, 2016, 03:50 |
#4 | |
Heather Kline
Rep Power: 14 |
https://github.com/su2code/SU2/blob/..._structure.cpp SU2_DEF uses some of the functions defined in the Common/ module. For the format of design variable specification, please see the config_template provided in the SU2/ directory, which has descriptions of the design variable formats. Examples are also available in the tutorials and test cases. |
CFX problems I got in Workbench | Anna Tian | CFX | 13 | July 3, 2017 02:49 |
Surface sensitivity projection onto custom made design variables | JanH | SU2 | 1 | May 12, 2015 17:47 |
JOB: Sr. Thermal/Mechanical Design Engineer | Dee Dee Dial | Main CFD Forum | 0 | April 1, 2003 19:49 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
CFD - Trends and Perspectives | Jonas Larsson | Main CFD Forum | 16 | August 7, 1998 17:27 |
