January 15, 2016, 10:49 |
SU2v4.1 Full Installation inside Cygwin
Eduardo Molina
Rep Power: 16 |
Hi guys...
For a full installation of SU2 inside Cygwin, just execute the following command: ./configure --prefix=$HOME_SU2 -enable-mpi --with-cc=/usr/bin/mpicc --with-cxx=/usr/bin/mpicxx -enable-metis --with-metis-cppflags="-D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_GETLINE -DMETIS_USE_LONGINDEX=1" -enable-parmetis --with-parmetis-cppflags="-DMETIS_USE_LONGINDEX=1" --with-CGNS-lib=/usr/local/lib --with-CGNS-include=/usr/local/include --disable-DOT --disable-MSH --disable-DEF --disable-SOL --disable-GEO The problem with parmetis/metis was solved using the cppflags. You need to have installed openmpi and cgns before execute the command above. Cheers... Molina |
January 21, 2016, 11:43 |
Problem installing SU2 on cygwin
Hi, I am a studen and would like to install SU2 to run my CFD simulations. However, when I try to make install i get an error.
$ make Making all in externals make[1]: Entering directory '/home/Balu/SU2/externals' Making all in tecio make[2]: Entering directory '/home/Balu/SU2/externals/tecio' CXX tecsrc/libtecio_a-TranslatedString.o CXX tecsrc/libtecio_a-alloc.o CXX tecsrc/libtecio_a-arrlist.o tecsrc/arrlist.cpp: In function ‘Boolean_t ArrayListIsValid(ArrayList_pa)’: tecsrc/arrlist.cpp:391:45: error: ‘VALID_REF’ was not declared in this scope Boolean_t IsValid = (VALID_REF(ArrayList) && ^ Makefile:505: recipe for target 'tecsrc/libtecio_a-arrlist.o' failed make[2]: *** [tecsrc/libtecio_a-arrlist.o] Error 1 make[2]: Leaving directory '/home/Balu/SU2/externals/tecio' Makefile:337: recipe for target 'all-recursive' failed make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory '/home/Balu/SU2/externals' Makefile:376: recipe for target 'all-recursive' failed make: *** [all-recursive] Error 1 any idea whats the mistake ? Thanks, Balu |
January 21, 2016, 16:12 |
Eduardo Molina
Rep Power: 16 |
Try disable TecIO support. Add --disable-tecio as an argument to the configure script. Thanks |
[snappyHexMesh] SHM error: inside mesh not possible | Naresh yathuru | OpenFOAM Meshing & Mesh Conversion | 1 | January 11, 2017 00:58 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
Modelling the Heat flow inside the curing oven | Marios Vlad | CFX | 1 | February 6, 2008 08:11 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
