Home > Forums > Software User Forums > SU2
Output of Jacobian matrix from SU2
Like Tree1Likes
  • 1 Post By talbring
Old   September 18, 2015, 16:34
Default Output of Jacobian matrix from SU2
Mandar Kulkarni
kmandar is on a distinguished road
I am implementing a method of obtaining flow sensitivities using Continuum Sensitivity Method. My current focus is Euler analysis. In the process, I want to output the Jacobain matrix and punch the elements of the matrix with high precision to text file, similar to what is done in the restart file.
a) Is there already a routine to punch out a matrix which I may use?
b) Is the structure (i.e. which elements are nonzero) of the sparse matrix available? I see that it is initialized in CSysMatrix::Initialize, but I could not follow the code to understand the structure.
Thanks,
Mandar
kmandar is offline   Reply With Quote
Old   September 26, 2015, 13:15
Mandar Kulkarni
I found these variables declared in matrix.hpp
    unsigned long *row_ptr;    /*!< \brief Pointers to the first element in each row. */
    unsigned long *col_ind;    /*!< \brief Column index for each of the elements in val(). */
I understand *row_ptr, but what is the meaning of *col_ind ?
I think these variables are related to the elements in the sparse matrix. Am I right?
Thanks,
Mandar
Old   October 6, 2015, 05:51
Tim Albring
talbring is on a distinguished road
Hi kmandar,
you are right, these variables are related to the sparse matrix entries. The matrix is stored using a (block) CRS format (http://netlib.org/linalg/html_templates/node91.html). To see how to loop through the entries take a look at the routine CSysMatrix::MatrixVectorProduct in matrix_structure.cpp.
kmandar likes this.
talbring is offline   Reply With Quote
Old   October 7, 2015, 15:15
Mandar Kulkarni
Hi talbring,
Thanks a lot. This is very helpful.
Regards,
Mandar
jacobian, matrix, output
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 13:08
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Nondimensional output from SU2 kmandar SU2 2 September 16, 2015 12:24
best setting for SU2 mechy SU2 3 April 20, 2014 20:13
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
