June 27, 2015, 06:43 |
fsi 3d
varghese mathew
Rep Power: 12 |
i have run the tutorial files for fsi 3d using version 4 .i have few doubts kindly help me out
1) after sucessful run when i use the tecplot to read the fea files struct_3D.dat the tecplot gives me error attached below .and the surface files give no data, just heading only within. 2) can i use the flow_surface to measure the displacement in the outer body of structure which may be indicated by variable "x". i know that the x in the structure dat file means displacement 1(along x) but it doesnt open please guide me through Last edited by varghese9; June 27, 2015 at 08:49. |
July 15, 2015, 14:04 |
R. Sanchez
Rep Power: 12 |
Hello, as of now the output for structural calculations (and for the FSI as a result) is only supported for Paraview. We will keep improving the features on SU2 in the coming months as the FSI development is an active area of work right now. Many thanks for your interest.
April 18, 2016, 07:22 |
Fsi
jit
Rep Power: 11 |
I'm trying to run FSI for some wing-fuselage problem using SU2 4.0.1
Problem: it runs only for INT_ITR (say 10) and keeps on running but without output i mean to say it doesn't go for further iterations or so I'm attaching cfg file and out.dat here any help would be appreciated Thanks |
User-defined force transfer across FSI interface | vivekcfd | CFX | 7 | March 10, 2010 21:43 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 05:14 |
fsi | sun | Siemens | 8 | January 20, 2009 00:17 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
FSI on a Rotating Structural Model | drgolf | CFX | 9 | August 30, 2007 13:08 |
