Home > Forums > Software User Forums > SU2
Periodic BC in SU2.!!!
Like Tree3Likes
  • 3 Post By economon
Old   April 24, 2015, 17:32
Default Periodic BC in SU2.!!!
Vino
Vino is on a distinguished road
I am simulating a shock instability case using SU2 in a square domain with unit length(shown below). I need to apply periodic boundary condition in top and bottom side. First I preprocessed with SU2_MSH and then I used the mesh_out.su2 file for simulation. I used the following in the config file.
MARKER_PERIODIC= ( top, bottom, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,bottom, top, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
I am not getting the expected results and I am not sure whether the BC specification is correct. Please clarify.
Thanks in advance.
Vino is offline   Reply With Quote
Old   May 14, 2015, 16:04
Thomas D. Economon
economon is on a distinguished road
Hi Vino,
For the periodic BC with the latest version of the code, you only need to provide the first half of your specification, i.e.,
MARKER_PERIODIC= ( top, bottom, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 )
Additionally, you need to provide the translational distance between the top and bottom instead of all zeros. If it was 1 m in the y-dir, for example, you would put
MARKER_PERIODIC= ( top, bottom, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, -1.0, 0.0 )
We also have an example of this for the VKI turbine in our test cases that are available. You can check out the config there for another example (see TestCases/rans/vki_turbine/).
Hope this helps,
Tom
Vino, leejearl and lutabanga like this.
economon is offline   Reply With Quote
Old   May 14, 2015, 16:53
Vino
Thank you very much economon.
This is what exactly I was looking for. Let me try now.
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
[ICEM] Periodic condition between ICEM and FLUENT Touré ANSYS Meshing & Geometry 0 August 5, 2012 18:00
HELP! Periodic Problem foxer FLUENT 1 June 27, 2012 09:00
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 18:46
