April 13, 2015, 04:31 |
Cp plot in Paraview with SU2 output
Yan Bochao
Rep Power: 12 |
Hi:
I am trying to plot a coefficient pressure along the airfoil of NACA0012 with SU2 output. In order to do this in Paraview (according to the answers I found in this forum), I need to get the value name of the airfoil and use it in the calculator. Is there anyone who knows how to figure out where is the value name or any other method that can makes me plot the pressure along the airfoil. Thanks |
April 14, 2015, 19:36 |
#2 | |
Heather Kline
Rep Power: 14 |
Which specific variables are output varies depending on the solution type. |
April 15, 2015, 07:10 |
#3 | |
Yan Bochao
Rep Power: 12 |
April 15, 2015, 16:20 |
Heather Kline
Rep Power: 14 |
Are you not able to use the surface_flow output? If you set the desired surface as MARKER_MONITORING in your config file you should have an output file with these values.
April 16, 2015, 11:30 |
#5 | |
Yan Bochao
Rep Power: 12 |
I found an answer in Google which said to get the data where u,v,w are equal to 0, but I can find it in the file. |
April 16, 2015, 15:49 |
#6 | |
Heather Kline
Rep Power: 14 |
Update: MARKER_PLOTTING is the option to use; marker_monitoring sets the marker on which to calculate integrated values (often these are the same). Last edited by hlk; April 16, 2015 at 17:15. |
May 8, 2015, 17:47 |
#7 | |
1- set Paraview as the post-processor in your config file instead of Tecplot. 2- Open the Paraview, click on open file, select the surface_flow.vtk that contain solution over surface, and press Apply. 3- While in the pipeline, surface_flow.vtk is selected, go to the Filters top menu, Alphabetical, and select Scatter Plot as the filter. 4- In the Properties, set the Attribute Mode to Point Data, and under the X Axis Data toggle the Use Data Array on Point(0). 5- Under in the Line Series, deselect all the variables, then check the Pressure Coefficient. Good Luck, PDP |
May 22, 2015, 19:34 |
D L
Rep Power: 14 |
For a 3D wing,
1. Generate slice in the orientation desired 2. TriangleStrips 3. CleantoGrid 4. ExtractSurface 5. ScatterPlot Then you can follow steps 4 and 5 that pdp.aero wrote |
June 2, 2016, 11:36 |
#9 | |
Rep Power: 14 |
I just ran the Euler Naca0012 testcase on SU2-4.1.2 (Ubuntu), and tried to repeat the steps above on ParaView 4.4.0 64bit. Unfortunately when I reach step 4, there seems to be no option to get the x-coordinates (i.e. Point(0)) for the x-axis. The list of possible variables for the x-axis are the residuals and flow properties: P, cp, Mach, T. This applies to both the "scatter plot" and "plot data" filters. What am I doing wrong? Many thanks in advance for any help. Alberto |
November 5, 2018, 11:32 |
#10 | |
Xiaolu Wang
Rep Power: 8 |
November 6, 2018, 05:57 |
#11 | |
Nathan Ricks
Rep Power: 11 |
November 6, 2018, 06:47 |
#12 | |
Xiaolu Wang
Rep Power: 8 |
Today I am trying the 5.5.2 version of paraview, yes, the x-coordinate can be seen now exactly. Previously, I used 4.4.0 version, I guess maybe the paraview learned that the 4 versions missed some functions, and recovered them in 5 versions. Thank you for discussion. Xiaolu |
[OpenFOAM] Paraview plot time average | tonyuprm | ParaView | 7 | December 24, 2023 20:02 |
Plot output parameter’s oscillation | Pierre1 | CFX | 1 | March 23, 2015 10:25 |
SU2 2.0.8 cannot output correct Paraview file | momo_sjx | SU2 | 2 | December 3, 2013 17:25 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
[OpenFOAM] Paraview Cp Plot | prapanj | ParaView | 0 | June 11, 2009 06:32 |
