April 9, 2015, 11:48 |
Mass flow inlet with given temperature
William Tougeron
Rep Power: 15 |
I would like to set a mass flow inlet with a given temperature. Is it possible in SU2? In the trunk/config_template.cfg, there is: Code:
% Inlet boundary type (TOTAL_CONDITIONS, MASS_FLOW) INLET_TYPE= TOTAL_CONDITIONS % % Inlet boundary marker(s) with the following formats (NONE = no marker) % Total Conditions: (inlet marker, total temp, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Mass Flow: (inlet marker, density, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. MARKER_INLET= ( NONE ) % Is this like this? Thanks! Best regards, William |
April 9, 2015, 23:31 |
#2 | |
Heather Kline
Rep Power: 14 |
The mass flow rate inlet condition enforces the specified mass flow rate. Other properties are determined from the flow solution, and updated as the iterations proceed. Enforcing the temperature as well as the mass flow rate would be nonphysical for a subsonic inlet because information propagating from downstream changes the flow state at the inlet. |
October 14, 2015, 23:41 |
Keisuke Minami
I want to set a inlet boundary condition with mass flow and pressure like ansys fluent. Your consideration of my request would be greatly appreciated. or could you tell me how to implement it? |
October 15, 2015, 14:25 |
#4 | |
Heather Kline
Rep Power: 14 |
If you want this functionality alongside the current boundary conditions, you may also want to make modifications to the Common/src/config_structure.cpp and associated files to be able to control which inlet type via the config file. Caveats if you are just starting out with learning to code/compile C++ and/or are using Windows: I strongly recommend doing this on a linux or Apple operating system - it is much, much harder to do this on a Windows operating system. Linux operating systems are generally free and can be used on a windows machine via virtual machines or a partition. I also recommend using an IDE such as XCode or Eclipse to make code navigation easier. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Loop of a inlet mass flow rate | .Thomas. | Fluent UDF and Scheme Programming | 2 | August 22, 2014 08:44 |
ON/OFF mass flow at an inlet boundary condition | visitor | FLUENT | 1 | April 12, 2014 12:07 |
Combination of mass flow inlet and pressure inlet boundaries | MrStuebb | Main CFD Forum | 0 | January 6, 2011 09:59 |
mass flow inlet | Mech | FLUENT | 2 | July 7, 2006 07:37 |
