Home > Forums > Software User Forums > SU2
su2 transition point and output settings
Like Tree1Likes
  • 1 Post By wgvanveen
Old   February 27, 2015, 06:16
Smile su2 transition point and output settings
varghese mathew
varghese9 is on a distinguished road
i have few doubts in cfd
1) can i set transition point in su2 for a particular analysis
2) in un-steady pitching and aero-elastic analysis i want only the history file to be written i dnt want to write the file output for other option like volume and surface flow data in windows os . do Su2 has any config option to do that
3) what does the full MG= yes does as it is giving me absurd pitching and plunging value compared to when its no i am using mg level = 3
if anybody has knowledge about the concerned above stated quiries ,please let me know
varghese9 is offline   Reply With Quote
Old   March 5, 2015, 10:30
Wouter
wgvanveen is on a distinguished road
Hey,
I can only give you an answer to question one. It is not standard in SU2 that you can pick a location in your grid from where the turbulence model starts working. However it is very easy to implement yourself. You can just add it in the method :void CTurbSASolver::Postprocessing a simple clause to set the muT to zero if it is before a certain point.
Hope it helps!
varghese9 likes this.
wgvanveen is offline   Reply With Quote
Old   March 5, 2015, 13:13
Smile
varghese mathew
thank you buddy .i will try that
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
How to output more digits after the decimal point in CFX post Anna Tian CFX 7 August 13, 2013 20:23
output point values in CFX4 Dougal McQueen CFX 1 February 14, 2004 00:55
Output from the Monitor point command swapnil CFX 0 November 20, 2002 23:08
