February 16, 2015, 09:37 |
SU2_MSH: Periodic boundary conditions bug
Rep Power: 17 |
I found a bug in SU2_MSH module conserned with periodic boundary setup. As far as i understand, SU2_MSH makes a set halo nodes on the one side of periodic boundary and marks nodes as halo on another boundary. After that, routine CPeriodicGeometry::SetMeshFile renumbers all nodes in order to have all halo nodes at the end of the list of nodes. To explain what the bug is, let's consider the mesh with 100 nodes, 2 periodic boundaries with 10 nodes each. SU2_MSH will produce totally corrupted mesh if we have nodes with numbers greater than 90 on the receive boundary. During the sort procedure, SetMeshFile routine looks for the receive nodes at the periodic boundary and places them at the end of list (with numbers from 90 to 99). But any receive node at the end of list destroys the sort algorithm since the new numbers of the found nodes would be also from 90 to 99. So this algorithm would rewrite any receive node at the end of list and would produce overlapping elements, single nodes with no elements, etc.
Remark: this algorithm would funсtion properly if all receive nodes are in descending order. In order to have property functioning algorithm, i have to introduce another boolean array in the routine SetMeshFile and split the sort procedure in two steps. On the first step i scan all receive nodes and place "true" in the array if the receive node at the end of list (with numbers from 90 to 99 in the example above) is found. After that i do the sort with respect to filled array: if i want to exchange two nodes and the relevant boolean array element is "true", i skip this node number until "false" in the array appears. Such a trick produces correct mesh file with periodic boundaries and halo nodes. Below you can see a part of the SetMeshFile code. Maybe proposed algorithm is not optimal (i'm not programmer), but it works. I hope that i explain what the bug is. Sorry for my poor english. Code: /*--- Ghost points, look at the nodes in the send receive ---*/ iMarkerReceive = nMarker - 1; GhostPoints = nElem_Bound[iMarkerReceive]; unsigned long recpnts = GhostPoints/2; bool prohibited[recpnts]; /*--- Change the numbering to guarantee that the all the receive points are at the end of the file ---*/ unsigned long OldnPoint = geometry->GetnPoint(); unsigned long NewSort[nPoint]; for (iPoint = 0; iPoint < nPoint; iPoint++) { NewSort[iPoint] = iPoint; if (iPoint < recpnts) prohibited[iPoint] = false; } for (iMarker = 0; iMarker < nMarker; iMarker++) { // First loop - fill prohibited array if (bound[iMarker][0]->GetVTK_Type() == VERTEX) { if (config->GetMarker_All_SendRecv(iMarker) < 0) { for (iElem_Bound = 0; iElem_Bound < nElem_Bound[iMarker]; iElem_Bound++) { if (bound[iMarker][iElem_Bound]->GetNode(0) < geometry->GetnPoint() && bound[iMarker][iElem_Bound]->GetNode(0) > nPoint - GhostPoints) { prohibited[bound[iMarker][iElem_Bound]->GetNode(0) - nPoint + GhostPoints] = true; } } } } } unsigned long Index = OldnPoint-1; for (iMarker = 0; iMarker < nMarker; iMarker++) { // Second loop - do the permutations if needed if (bound[iMarker][0]->GetVTK_Type() == VERTEX) { if (config->GetMarker_All_SendRecv(iMarker) < 0) { for (iElem_Bound = 0; iElem_Bound < nElem_Bound[iMarker]; iElem_Bound++) { if (bound[iMarker][iElem_Bound]->GetNode(0) < nPoint - GhostPoints) { while (prohibited[Index - nPoint + GhostPoints]) Index--; NewSort[bound[iMarker][iElem_Bound]->GetNode(0)] = Index; NewSort[Index] = bound[iMarker][iElem_Bound]->GetNode(0); Index--; } } } } } The rest of the SetMeshFile routine stays the same. |
February 18, 2015, 13:28 |
Francisco Palacios
Rep Power: 15 |
Thanks a lot for your contribution,
In fact, these days we are updating the Periodic BC and your comments are very useful. I'll keep you posted. Best, Francisco Palacios SU2 lead developer |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
PEMFC module + multiple periodic boundary conditions | vkrastev | FLUENT | 2 | December 22, 2014 04:15 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Problem with Periodic Boundary Conditions Help!!! | otsigun | FLUENT | 0 | July 11, 2013 03:20 |
periodic boundary conditions fro pressure | Salem | Main CFD Forum | 21 | April 10, 2013 00:44 |
