January 7, 2015, 11:41 |
Explicit RK time integration in SU2.!!!
Vino
Rep Power: 13 |
I would like to know what is the order of accuracy of the RK used in SU2. It uses three co-efficient, means three stage. If I want to make it even higher stage, say 4 stage, can I just add 4 co-efficient in config file.? or do I need to re-implement the RK in time_integration file? Also I would like to the implemented is the classical RK method, or Modified RK method (mainly for higher stability margin)? If possible, can I get the reference of the RK method implemented in SU2. Thank you. |
January 15, 2015, 13:13 |
#2 | |
Francisco Palacios
Rep Power: 15 |
Hi. The implementation is generic, you just need to change the coefficients to add more integration stages. The method is the one that you can find in most of Profesor Jameson's papers. Like http://aero-comlab.stanford.edu/Pape....1981-1259.pdf Best Regards, Francisco Palacios SU2 lead developer |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 10:08 |
Fully explicit time accurate simulation | nilesh | SU2 | 2 | June 5, 2014 16:20 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
