Home > Forums > Software User Forums > SU2
Using LAPACK in SU2
Like Tree1Likes
  • 1 Post By mpini
Old   November 3, 2014, 02:38
Default Using LAPACK in SU2
Shainath
shainath is on a distinguished road
I want to use functions of LAPACK(Linear Algebra PACKage) in SU2 code. Please give some guidelines to do so. Thank you.
shainath is offline   Reply With Quote
Old   November 27, 2014, 08:04
Matteo Pini
mpini is on a distinguished road
Here below some instructions to use LAPACK and LAPACK with SU2. Please consider that such illlustration refers to the coupling we are carrying on internally at TU-Delft. In due course and after proper discussion with the rest of the developers LAPACK lib will be available in SU2 develop branch.
LAPACK-dir is the directory where the lapack lib is installed.
Installation of LAPACK:
1) Unzip lapack gz-file.
2) Copy the make.inc for the desired Fortran compiler from INSTALL to LAPACK-dir (in my case I copied make.inc.ifort [=Intel Fortran] and renamed it to make.inc).
3) Change in make.inc the line CC = icc to CC = gcc, if you need to use a different compiler than the one from Intel.
4) In Makefile, in the line starting with “lib:” add liblapacke.lib (and probably also blas.lib).
5) Compile LAPACK on your system by running make.
Enable in SU2:
1) Probably first: ./bootstrap
2) Then: ./configure --with-LAPACK-lib=LAPACK-dir/ --with-LAPACK-include=LAPACK-dir/lapacke/include/
3) Next the usual: make and make install
4) the header file to be used in your code in order to enable a lapack subroutine is lapacke.h
Best regards,
Matteo
shainath likes this.
mpini is offline   Reply With Quote
Old   November 28, 2014, 01:34
Default Lapack
Shainath
Dear Matteo Pini,
Thank you for information. I will surely look into it.
Tool to download: SU2 post-processing Combas SU2 2 June 5, 2014 15:55
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 03:40
Official release of SU2 V3.0 and SU2 Educational V1.0 fpalacios SU2 News & Announcements 2 January 22, 2014 06:28
SU2 suite has moved to GitHub! fpalacios SU2 News & Announcements 0 August 12, 2013 03:07
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
