October 24, 2014, 05:36 |
Reynolds Lenght in SU2.!
Vino
Rep Power: 13 |
I am bit confused with the parameter Reynolds Length, mainly for Incompressible flows. Let us say, I would like to simulate flow over cylinder at Re=100. If I keep my cylinder diameter as 1 unit in mesh file, then keeping Reynolds Length as 1 , it will give me Reynolds no of 100 for the following parameters (rho=1,u=1,mu=0.01) If I keep my cylinder diameter as 10 unit in mesh file, then keeping Reynolds Length as 1, will it give me Reynolds no of 100?(other parameters are same as above) or Do I need to specify Reynolds Length as 10? |
October 26, 2014, 00:16 |
Heather Kline
Rep Power: 14 |
Thank you for your interest in SU2.
For the incompressible solver, the Reynolds number is not used to specify the freestream flow, rather it is specified with something like below (copied from one of the test cases in the github su2code/testcases folder). In general the test cases folder is a good resource for identifying which parameters are needed for different types of simulations. % -------------------- INCOMPRESSIBLE FREE-STREAM DEFINITION ------------------% % % Free-stream density (1.2886 Kg/m^3 (air), 998.2 Kg/m^3 (water)) FREESTREAM_DENSITY= 2.13163 % % Free-stream velocity (m/s) FREESTREAM_VELOCITY= ( 52.1572, 0.00, 0.00 ) % % Free-stream viscosity (1.853E-5 Ns/m^2 (air), 0.798E-3 Ns/m^2 (water)) FREESTREAM_VISCOSITY= 1.853e-05 |
October 26, 2014, 03:43 |
Vino
Rep Power: 13 |
Thank you for your answer.
I am clear with the config setting for incompressible flow. I have a bit confusion on setting Reynolds Length, not on Reynolds Number. I found that changing Reynolds Length is changing my Reynolds number, time & time step (printed in console output at the beginning of the simulation). I hope the above question is clear. Thanks once again.!! |
October 26, 2014, 15:01 |
#4 | |
Heather Kline
Rep Power: 14 |
The Reynolds number (which uses the reynolds length in its calculation) is used in determining the solver time step. Changing the Reynolds length in the incompressible solver is inadvisable, because that may do unexpected things to the solution. For the incompressible solver, it does not matter what the characteristic length of your geometry is, only that the mesh is in meters. |
October 26, 2014, 15:46 |
Vino
Rep Power: 13 |
Thank you.!!!
What I understood is that, whether cylinder dia is 1 m or 10 m in the mesh file, keep Reynolds length as always 1 and modify other parameters to get the required Reynolds number. I set (rho=1, v=1, mu=0.01)to achieve Re=100. It hold true irrespective of what cylinder dia I am using in mesh file(1m or 10m). Last edited by Vino; October 27, 2014 at 04:35. |
October 27, 2014, 04:38 |
Least Square solution algorithm in SU2?
Vino
Rep Power: 13 |
plz ignore this Least Square solution algorithm post here.!
Official Release of SU2 V3.2 | economon | SU2 News & Announcements | 6 | April 17, 2015 23:28 |
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release | fpalacios | SU2 News & Announcements | 1 | April 30, 2014 02:40 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 05:28 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
CFX Solver Reynolds Number | haider760 | CFX | 2 | March 4, 2012 22:05 |
