Home > Forums > Software User Forums > SU2
non-physical points
Like Tree1Likes
  • 1 Post By Vino
Old   September 18, 2014, 23:50
Default non-physical points
wangjian
jwang1_09 is on a distinguished road
I simulate a supersonic aircraft with SU2, but it appears there are some non-physical points until the end. I wonder whether the result is credible. Could you help me. Thanks.
jwang1_09 is offline   Reply With Quote
Old   September 19, 2014, 05:41
Vino
Vino is on a distinguished road
Can u tell me more about your config what u are using exactly?
1) Some solvers like AUSM was having problem for CFL=0.9 (EULER_EXPLICIT) when I was simulation a 2D blunt body at M=20. When I reduced the CFL to 0.5 . it was working fine.
2) If you are using steady simulation, by default It uses local time stepping, you may have to add UNSTEADY_SIMULATION=TIME-STEPPING to make it global time stepping. (local time stepping was creating non-physical points for my case)
These are the two things I have done for my case and my problem got solved.
Thanks.!!!
mlooti likes this.
Vino is offline   Reply With Quote
Old   September 19, 2014, 06:01
wangjian
This is my config file. I wonder wherther the non-physical points is related to the quality of mesh?
Old   September 19, 2014, 06:36
wangjian
Old   September 19, 2014, 15:34
Vino
Config file looks fine for me. As you said, there may be problem with mesh quality. One more thing you can try out is, use MSW spatial discretization instead of AUSM. you can try with out multi-grid also.
This may also help you.
http://www.cfd-online.com/Forums/su2...al-points.html
Thanks.!!!
Old   September 19, 2014, 22:30
wangjian
Thank you.
Old   September 21, 2014, 06:28
wangjian
I use the same mesh within fluent software. The hypersonic simulation results is good. But it always appears some non-physical points in SU2. Could someone help me?
Old   September 21, 2014, 09:14
Khiem Pham
Bachduong is on a distinguished road
Hi Wang
I'm trying to run SU2_MSH for airfoil RAE_2822, but when i'm using mesh_out.su2, i have an error.
Could you please send me a config file (with grid adaptation options) and restart files (i.e flow_solution, adjoint files..) of your case?
Thank you
Bachduong is offline   Reply With Quote
Old   September 21, 2014, 12:08
wangjian
Hi, this is my files. I only try the MSH with naca0012.
Old   September 21, 2014, 12:54
Khiem Pham
Thank you very much!
Old   September 26, 2014, 21:44
Francisco Palacios
fpalacios is on a distinguished road
Please find in this link the reply to this post.
"This week in SU2": Wednesdays at 10:00am (PDT) on YouTube.
Best,
The SU2 team
fpalacios is offline   Reply With Quote
Old   September 26, 2014, 22:48
wangjian
Thanks!!!!
Old   September 27, 2014, 09:47
wangjian
Best,
The SU2 team
Hello,Francisco Palacios
I couldn't understand the explanation on YouTubu for my bad English listening. Could you explain again about this question. Thank you very much.
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 04:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 16:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
