April 29, 2014, 18:04 |
SU2 KeyError: 'SU2_RUN'
The error I keep getting occurs when I try to run one of the python scripts within SU2. I've been working through the user tutorials and in Tutorials 2 & 7 where scripts are an option to execute problem. The scripts I've tried to use so far are parallel_computation.py and shape_optimization.py. I get mainly a KeyError: 'SU2_RUN', but have had a few TypeError: NoneType. Note the C++ modules run perfectly fine for me when called directly on their own.
I'm running Windows 7 64 bit, SU2 V3.0, Python 2.7.2. I've followed the windows installation guide all the way through and have tried a few re-installs to see if that fixes my issue, as well as different directories, and re-doing all the system environment variables required. Anything I've tried so far hasn't fixed it, so any help/ideas would be greatly appreciated! Please see the errors below. Code:
C:\SU2>parallel_computation.py -f inv_ONERAM6.cfg -p 4 Traceback (most recent call last): File "C:\SU2\parallel_computation.py", line 25, in <module> sys.path.append(os.environ['SU2_RUN']) File "C:\Python27\lib\os.py", line 423, in __getitem__ return self.data[key.upper()] KeyError: 'SU2_RUN' Code:
C:\SU2>python shape_optimization.py f rot_NACA0012.cfg Traceback (most recent call last): File "shape_optimization.py", line 25, in <module> sys.path.append(os.environ['SU2_RUN']) File "C:\Python27\lib\os.py", line 423, in __getitem__ return self.data[key.upper()] KeyError: 'SU2_RUN' Code:
C:\SU2>parallel_computation.py -f inv_ONERAM6.cfg -p 4 Traceback (most recent call last): File "C:\SU2\parallel_computation.py", line 26, in <module> import SU2 File "C:\SU2\SU2\__init__.py", line 13, in <module> if 'libedit' in readline.__doc__: TypeError: argument of type 'NoneType' is not iterable |
April 29, 2014, 18:14 |
Trent Lukaczyk
Rep Power: 15 |
python is looking for an environment variable called SU2_RUN. you'll need to add this to your system. check out step two of these instructions -
http://adl-public.stanford.edu/docs/...s+Installation |
April 29, 2014, 18:33 |
No worries, I did actually have SU2_RUN as a system variable already. I added it as a local user variable as well and I'm no longer seeing the KeyError. I'm now getting this TypeError every time I try to execute a script.
C:\SU2>python shape_optimization.py -f rot_NACA0012.cfg Traceback (most recent call last): File "shape_optimization.py", line 26, in <module> import SU2 File "C:\SU2\SU2\__init__.py", line 13, in <module> if 'libedit' in readline.__doc__: TypeError: argument of type 'NoneType' is not iterable Code:
May 7, 2014, 03:43 |
Trent Lukaczyk
Rep Power: 15 |
doh, that's the code that adds tab-complete when working interactively. you can go into that file (SU2/SU2/__init__.py) and remove all lines after line 10. we'll fix this for the next release
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release | fpalacios | SU2 News & Announcements | 1 | April 30, 2014 02:40 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 05:28 |
SU2 suite has moved to GitHub! | fpalacios | SU2 News & Announcements | 0 | August 12, 2013 02:07 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
New SU2 Forum Opened at CFD Online | pete | Site News & Announcements | 0 | January 5, 2013 17:59 |
