Home > Forums > Software User Forums > SU2
[Tutorial 3] Doubts about iteration number
Like Tree2Likes
  • 2 Post By economon
Old   April 16, 2014, 21:04
Default [Tutorial 3] Doubts about iteration number
Carlos Alexandre Tomigawa Aguni
CrashLaker is on a distinguished road
Did anyone do the Tutorial 3 (Laminar Cylinder)?
Why is it set to do 9999 iterations?
If it's possible to change that what's the best suitable number to put?
Thanks in advance!
Edit1:
This thread has advanced! Please check my following posts!
CrashLaker is offline   Reply With Quote
Old   April 16, 2014, 21:24
I've noticed that 9999 was the maximum number of iterations..
So where do I find how many iterations is it set to do?
My program goes far till 7k then crashes...
Any help?
Old   April 16, 2014, 23:19
I've just realized that running it in serial the calculations don't reach the breaking point (this I suppose is the convergence they talk about on the tutorial).
So.. when running it in serial or setting np = 1 (if one use any mpi implementation) it just goes till the 9999th iteration
Can you explain why is that?
Example where I've set np = 2
Iter Time(s) Res[Rho] Res[RhoE] CLift(Total) CDrag(Total)
420 0.798929 -11.861028 -6.468419 -0.005113 1.548706
421 0.798910 -11.869982 -6.480136 -0.005113 1.548706
422 0.798895 -11.878834 -6.491870 -0.005113 1.548706
423 0.798879 -11.887588 -6.503607 -0.005113 1.548705
424 0.798863 -11.896239 -6.515355 -0.005113 1.548705
425 0.798847 -11.904784 -6.527122 -0.005113 1.548705
426 0.798834 -11.913214 -6.538915 -0.005113 1.548705
427 0.798823 -11.921537 -6.550715 -0.005113 1.548705
428 0.798811 -11.929736 -6.562532 -0.005113 1.548705
429 0.798797 -11.937814 -6.574367 -0.005113 1.548705
430 0.798782 -11.945750 -6.586230 -0.005113 1.548705
431 0.798766 -11.953555 -6.598090 -0.005113 1.548705
432 0.798750 -11.961219 -6.609973 -0.005113 1.548705
433 0.798734 -11.968734 -6.621870 -0.005113 1.548705
434 0.798716 -11.976098 -6.633788 -0.005113 1.548705
435 0.798698 -11.983323 -6.645670 -0.005113 1.548704
436 0.798683 -11.990378 -6.657576 -0.005114 1.548704
437 0.798675 -11.997265 -6.669486 -0.005114 1.548704
438 0.798658 -12.003985 -6.681365 -0.005114 1.548704
History file, closed.
Example when I run it in serial
7860 1.396446 -11.777780 -5.518481 -0.005118 1.548717
7861 1.396445 -11.776718 -5.518419 -0.005118 1.548717
7862 1.396443 -11.777780 -5.518481 -0.005118 1.548717
7863 1.396442 -11.776718 -5.518419 -0.005118 1.548717
7864 1.396440 -11.777780 -5.518481 -0.005118 1.548717
7865 1.396438 -11.776718 -5.518419 -0.005118 1.548717
7866 1.396437 -11.777780 -5.518481 -0.005118 1.548717
7867 1.396436 -11.776718 -5.518419 -0.005118 1.548717
7868 1.396435 -11.777780 -5.518481 -0.005118 1.548717
7869 1.396433 -11.776718 -5.518419 -0.005118 1.548717
7870 1.396431 -11.777780 -5.518481 -0.005118 1.548717
7871 1.396430 -11.776718 -5.518419 -0.005118 1.548717
7872 1.396430 -11.777780 -5.518481 -0.005118 1.548717
7873 1.396427 -11.776718 -5.518419 -0.005118 1.548717
7874 1.396427 -11.777780 -5.518481 -0.005118 1.548717
7875 1.396425 -11.776718 -5.518419 -0.005118 1.548717
7876 1.396422 -11.777780 -5.518481 -0.005118 1.548717
7877 1.396422 -11.776718 -5.518419 -0.005118 1.548717
7878 1.396421 -11.777780 -5.518481 -0.005118 1.548717
You can see that Cdrag and Clift remains the same after each iteration. And "res" is repeating by 2. After that my process crashed (but this was a problem with my cluster so.. it should've ran up to the 9999th iteration).
Old   April 18, 2014, 10:19
Francisco Palacios
fpalacios is on a distinguished road
You are probably satisfying another criteria before arriving to the maximum number of iterations.
Currently we SU2 have in place CAUCHY and RESIDUAL which are controlled by
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
% Convergence criteria (CAUCHY, RESIDUAL)
CONV_CRITERIA= RESIDUAL
% Residual reduction (order of magnitude with respect to the initial value)
RESIDUAL_REDUCTION= 5
% Min value of the residual (log10 of the residual)
RESIDUAL_MINVAL= -8
% Start convergence criteria at iteration number
STARTCONV_ITER= 10
% Number of elements to apply the criteria
CAUCHY_ELEMS= 100
% Epsilon to control the series convergence
CAUCHY_EPS= 1E-10
% Direct function to apply the convergence criteria (LIFT, DRAG, NEARFIELD_PRESS)
CAUCHY_FUNC_FLOW= DRAG
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   April 18, 2014, 11:55
Hello Francisco! Thanks for your reply!
But the config files were supposed to work without any modification right?
The thing is that with the same config the serial execution doesn't finishes and setting np = 2 it takes just few seconds to accomplish.
Why is that?
Thanks in advance.
Carlos.
Old   April 24, 2014, 05:54
Thomas D. Economon
economon is on a distinguished road
Hi Carlos,
As Francisco mentions above, the simulation will terminate if any of the following criteria is met (whichever happens first):
1. The magnitude of the density residual drops the specified number of orders relative to the initial value, e.g., -2 -> -7 if 5 orders reduction is requested
2. The density residual reaches the specified minimum value in RESIDUAL_MINVAL
3. The simulation hits the max number of allowed iterations in EXT_ITER
Lastly, note that, depending on the chosen methods, the residual history will not be the same for serial and parallel calculations. This is likely why one of the conditions above is being met in serial and not in parallel, or vice-versa.
Hope this helps clear it up,
Tom
CrashLaker and helicopterliu like this.
economon is offline   Reply With Quote
Old   April 28, 2014, 00:21
Originally Posted by economon View Post
Hi Carlos,
Tom
Thank you so much Economon
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Iteration number for junction box routine Allan CFX 8 March 8, 2018 07:55
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 23:30
