Home > Forums > Software User Forums > SU2
Meaning of non-physical points ...
Like Tree1Likes
  • 1 Post By fpalacios
Old   December 27, 2013, 02:56
Default Meaning of non-physical points ...
deeps is on a distinguished road
Hi All,
I had few queries regarding SU2 terminology.
1. Several times I encounter this msg: The solution contains n non-physical points. What does this refer to ?
2. How are the residuals defined? Lets say the value at some iteration for variable 1 is -3.4567. What does it indicate? Does it mean log_10 (Var1_i iter/ Var1_ i-1 iter)?
3. Has anyone tried using 2 level Multigrid? How to decide optimal child/parent ratio for a given grid?
Would appreciate your response.
Thanks,
Deepanshu.
deeps is offline   Reply With Quote
Old   January 11, 2014, 23:05
Francisco Palacios
fpalacios is on a distinguished road
Non-physical points means that after the solution update the density is negative.
Su2 computed the L2 norm of the residual and plots the Log10 of the value. In other words a value of -12 means that the residual is 10^-12.
To set the optimal parameters of the MG is an art. when you have convergence issues do not forget to reduce:
% Damping factor for the residual restriction
MG_DAMP_RESTRICTION= ____
% Damping factor for the correction prolongation
MG_DAMP_PROLONGATION= ____
Best Regards,
Francisco
akun646 likes this.
fpalacios is offline   Reply With Quote
Old   January 13, 2014, 01:20
Dear Francisco,
Thank you for your inputs.
Deepanshu.
Old   January 14, 2014, 18:51
Sean (J.X.) Shi
momo_sjx is on a distinguished road
Set Multigrid=0, the non-physical points can be removed.
It works sometimes for me.
momo_sjx is offline   Reply With Quote
Old   January 29, 2014, 02:04
Thanks Sean for your inputs.
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 04:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 16:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
