Home > Forums > Software User Forums > SU2
Which Meshing software can I use?
Like Tree2Likes
  • 1 Post By onyir
  • 1 Post By kiski
Old   July 15, 2013, 07:03
Default Which Meshing software can I use?
Sreekanth
shsreekanth is on a distinguished road
I am familiar with Meshing in GAMBIT. The meshes created are in .msh format.
But SU2 requires the mesh to be in .SU2 format or .CGNS format. Is there a way to convert the mesh generated in GAMBIT to CGNS format?
If not, can you tell me another suitable meshing software.
I tried EnGrid, but it requires another CAD software for geometry creation. The website suggested Blender for this. I tried Blender 2.6, but it doesnt have an option to export the geometry in .begc format as required for EnGrid. EnGrid website says it accepts .stl format, but when I try to import anything in .stl format in Engrid, it crashes (Fedora 16).
shsreekanth is offline   Reply With Quote
Old   July 16, 2013, 07:14
Sreekanth
I know to generate boundary layer mesh in GAMBIT. I tried one, exported it in CGNS format using fluent. But when SU2 reads the mesh it throws an error.
"!!! Error !!! Unrecognized element type."
The same error does not occur if there is no boundary layer mesh. How can I get around this problem
Old   July 17, 2013, 04:19
RDG
onyir is on a distinguished road
To be able to export in begc format from Blender you need to install the proper addon. The addons it's in the engrid installation directory. To install it in Blender, in the user preferences, click on Install from file... and select file in engrid folder
shsreekanth likes this.
onyir is offline   Reply With Quote
Old   July 17, 2013, 15:27
Sreekanth
Thank you onyir, I got the "export to engrid (*.begc) " option now in Blender
Old   July 22, 2013, 05:26
David
kiski is on a distinguished road
I have also been working for a while with blender and engrid in order to create meshes for SU2. But after a while I found it difficult to work with because working with .stl is not as easy as working with a CAD file if modifications has to be done. Additionally, I found some errors when running meshes with prisms created by Engrid. The simulation reports something about "negative pressure..." for very simple and curved geometries.
In short, I decided to move to Salome-platform. I find it good enough to work with my geometries. You can actually create the CAD and the grid with this software. I am very happy with my new option. However, you cannot export to .SU2, but you can export .unv to gmsh, from here export again in .vtk to engrid, and in engrid define boundaries and export to .su2.
I used to work like this for a while. Now I am just mastering Salome and I created my own scripts to export from Salome to .SU2 directly. And meshing velocity of Salome is just much faster than Engrid.
Hope it helps
kiski is offline   Reply With Quote
Old   July 22, 2013, 05:54
Sreekanth
Thanks kiski for a timely reply.
Since I am just getting started, it really helps to find the better option and proceed with that. I am not familiar with Blender or Engrid and now that I know its drawback, it saves me time.
Will give a try to Salome. Also, I hear that Larosterna mesh generator now has option to export in SU2.
Old   July 22, 2013, 05:59
David
I never heard about Larosterna. But it is good to know it exists :-)
About salome, if you are using Linux, it is easier if you install the "universall binaries", other options gave me hard time trying to compile!!
Old   July 22, 2013, 06:05
Sreekanth
Hi Kiski,
Thanks for the tip. How did you export directly to .SU2 from Salome ? Can you share?
Old   July 22, 2013, 06:33
David
Hi shsreekanth,
I am modifying a lot the script I use until I get a final version, which will take me a while since I am working in other things as well. However, you can have a look in this forum in which I posted a script for unstructured meshes with prisms.
If I remember well, it exports the first mesh entry (in case you have more than one mesh computed), and the boundaries of the .su2 file are the "mesh groups" within the mesh you created in Salome. The way to work is, once you have the mesh you want to export, in salome Load the file in the post through the Salome menu and it will export your mesh to your $home directory. Have a look to the code of the script, because it is pretty simple and you can adapt it yourself.
Old   July 22, 2013, 06:40
Sreekanth
Thank you. I will try that
Old   July 22, 2013, 07:40
Sreekanth
To get around the error - "Unrecognized element type"- this thread deals with it http://www.cfd-online.com/Forums/su2/113393-cgns-grid-problem.html
Old   July 22, 2013, 07:41
Sreekanth
Larosterna can be found here http://www.larosterna.com/index.html
Old   July 22, 2013, 07:48
David
thanks for sharing all this. About the "Unrecognized element type" y wrote it in the file only to mention that I didn't make "write to file" sopport of this element type. For example, hexas are not included in my script although there is no problem in .su2 or Salome. It just has to be included in the script as it was included for tetras
Old   July 25, 2013, 13:46
Trent Lukaczyk
rktchip is on a distinguished road
Hey kiski,
would you mind sharing your export scripts with the community? These would be very cool to see!
- Trent
rktchip is offline   Reply With Quote
Old   July 27, 2013, 13:06
David
Hi rktchip,
Look in the post entry #9, I am modifying the scripts in order to have only one script for any kind of mesh. But now I am in holidays XD. In entry #9 you have a script which works
[GAMBIT] GAMBIT or ANSYS Meshing software mohammadx90 ANSYS Meshing & Geometry 16 October 24, 2017 03:55
Is there a meshing tool within the Ansys Fluent software srikanth ANSYS 5 March 21, 2010 15:04
CAD integrated CFD Software kostikr Main CFD Forum 3 February 4, 2010 15:38
need software to heal/prepare geometry for meshing Mike Marcu Main CFD Forum 0 September 20, 2005 12:38
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
