Home > Forums > Software User Forums > SU2
Problem with plasma test case: residuals are NAN
Like Tree2Likes
  • 1 Post By Amrita Lonkar
  • 1 Post By rafpepe
Old   January 19, 2013, 12:14
Default Problem with plasma test case: residuals are NAN
Raffaele Pepe
rafpepe is on a distinguished road
Hello, I have installed SU2 from source code on Ubuntu 12.10.
I ran serial SU2_CFD code and it works well for most of the test cases, except for ~/TestCases/multi_species_plasma/react_argon/ test case. In this case residuals are equals to NAN.
I did not make any changes to the configuration file plasma_argon_3D.cfg.
What could be the problem?
Thanks in advance.
Raffaele
rafpepe is offline   Reply With Quote
Old   January 19, 2013, 14:56
Amrita Lonkar
Amrita Lonkar is on a distinguished road
I am informed of this problem, the problem is not in the solver, the problem is in the restart file.
This particular test case uses a restart file which contains a solution of the multi-species Euler equations. This restart file is used to start a simulation of multi-species plasma equation, but somehow, the restart file that I provide with this test case is not being read correctly on other computers.
Therefore this is what I suggest:
1) Use the following attached config file with the same mesh (mesh_plasma_argon_3D.su2) that you have for the plasma solver, and run it to generate your own restart file.
2) This will produce a restart file named "restart.dat".
3) Rename this file to restart_in.dat and copy it to the directory where you want to run the multi-species plasma simulation.
4) Run the configuration file (plasma_argon_3D.cfg) for the plasma solver that came with the code and obtain a solution.
This way, you have just created a new restart file for the multi-species plasma simulation that should work on your computer.
rafpepe likes this.
Amrita Lonkar is offline   Reply With Quote
Old   January 20, 2013, 10:37
Raffaele Pepe
Thanks for your answer.
I followed your instructions and the code works well on my computer.
Amrita Lonkar likes this.
argon, nan, plasma, residuals, test cases
F-packing problem Streamlet FLOW-3D 4 April 29, 2011 04:41
Unfamiliar Error coops OpenFOAM Running, Solving & CFD 7 October 3, 2006 14:54
Porous Media test case Alex FLUENT 0 April 9, 2006 09:23
Flat Plate Transition Test Case Adam CFX 1 June 24, 2005 00:12
c1 body test case Eric Lenormand Main CFD Forum 0 March 2, 2000 07:54
