Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Visualise FFD boxes and other outputs
Like Tree1Likes
  • 1 Post By pcg
Old   May 14, 2020, 05:57
Default Visualise FFD boxes and other outputs
Joe
joe.coppin is on a distinguished road
I downloaded, compiled SU2 v7.0.4 from source. When I run shape_optimization.py or SU2_DEF I do not seem to get any output to visualize the FFD boxes.
I have tried adding VISUALIZE_SURFACE_DEF=YES although I am not sure what effect this had.
Can anyone explain how to do this? Or has this functionality fallen though the cracks with the latest version.
There also doesn't seem to be a file containing the history of the design variables - apart from possibly in the cryptic .pkl files.
Any help much appreciated.
Thanks,
joe.coppin is offline   Reply With Quote
Old   May 14, 2020, 16:31
pcg
Pedro Gomes
pcg is on a distinguished road
Try enabling also VISUALIZE_VOLUME_DEF and make sure OUTPUT_FILES contains a surface format e.g. SURFACE_PARAVIEW.
pcg is offline   Reply With Quote
Old   November 3, 2020, 17:57
Zen
Zeno
Zen is on a distinguished road
Hi Pedro,
I tried your suggestion, i.e. having VISUALIZE_VOLUME_DEF = YES, OUTPUT_FILES = (..., SURFACE_TECPLOT), DV_KIND = FFD_SETTING, and all the other FFD parameters set up correctly for creating the FFD box.
Then I would run SU2_DEF ***.cfg and the output would be a volume_deformed.vtu and surface_deformed.vtu files which do not contain the FFD box but only the volume/surface mesh.
Any idea what else could work for the visualization of the FFD box itself?
Zeno
Zen is offline   Reply With Quote
Old   November 4, 2020, 13:20
pcg
Pedro Gomes
Hi Zeno,
Try adding TECPLOT or TECPLOT_ASCII to the output files.
I guess the logic is that the FFD is considered a volume output.
Cheers,
Pedro
Zen likes this.
Old   April 14, 2021, 02:51
Daaman is on a distinguished road
Hi, I'm using the 7.1.1 version at the moment and tried the above suggestions. On using the suggestions, I'm able to get the surface_deformed.szplt and volume_deformed.szplt files which depict the deformed meshes. The options VISUALIZE_VOLUME_DEF and VISUALIZE_SURFACE_DEF are apparently deprecated in the latest version, and I still can't visualize the FFD boxes. Is there any other way to visualize them?
Thanks
Daaman is offline   Reply With Quote
Old   April 28, 2021, 12:15
Omur Icke
eromir is on a distinguished road
if you use the following flags,
VISUALIZE_SURFACE_DEF= YES
VISUALIZE_VOLUME_DEF= YES
OUTPUT_FILES= (TECPLOT,SURFACE_TECPLOT)
you must be able to see
surface_deformed_00000.szplt
volume_deformed_00000.szplt
ffd_boxes.dat
which are showing the deformed surface, volume and ffd boxes respectively.
eromir is offline   Reply With Quote
