March 10, 2020, 13:45 |
KeyError for OPT_OBJECTIVE option
Nicolas
Hi everyone,
I am working on the shape optimization of a cooling channel using SU2 v.7.0.2. The flow studied is a steady incompressible turbulent water flow. For the optimization, I use a 3D FFD box for the design variables, and a weigthed sum for the objective function with the options SURFACE_TOTAL_PRESSURE and TOTAL_HEATFLUX. Code:
% ---------------- ADJOINT-FLOW NUMERICAL METHOD DEFINITION -------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, ROE) CONV_NUM_METHOD_ADJFLOW= ROE % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the adjoint flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_ADJFLOW= YES % % Slope limiter (NONE, VENKATAKRISHNAN, BARTH_JESPERSEN, VAN_ALBADA_EDGE, % SHARP_EDGES, WALL_DISTANCE) SLOPE_LIMITER_ADJFLOW= NONE % % 2nd, and 4th order artificial dissipation coefficients ADJ_JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT) TIME_DISCRE_ADJFLOW= EULER_IMPLICIT % % Relaxation coefficient RELAXATION_FACTOR_ADJFLOW= 1.0 % % Reduction factor of the CFL coefficient in the adjoint problem CFL_REDUCTION_ADJFLOW= 0.8 % % Limit value for the adjoint variable LIMIT_ADJFLOW= 1E15 % % Multigrid adjoint problem (NO, YES) MG_ADJFLOW= NO % % Objective function in gradient evaluation (DRAG, LIFT, SIDEFORCE, MOMENT_X, MOMENT_Y, MOMENT_Z, EFFICIENCY, EQUIVALENT_AREA, NEARFIELD_PRESSURE, FORCE_X, FORCE_Y, FORCE_Z, THRUST, TORQUE, FREE_SURFACE, TOTAL_HEATFLUX, MAXIMUM_HEATFLUX, INVERSE_DESIGN_PRESSURE, INVERSE_DESIGN_HEATFLUX, SURFACE_TOTAL_PRESSURE, SURFACE_MASSFLOW) % For a weighted sum of objectives: separate by commas, add OBJECTIVE_WEIGHT and MARKER_MONITORING in matching order. OBJECTIVE_FUNCTION = SURFACE_TOTAL_PRESSURE, TOTAL_HEATFLUX % % List of weighting values when using more than one OBJECTIVE_FUNCTION. Separate by commas and match with MARKER_MONITORING. OBJECTIVE_WEIGHT= 0.5,0.5 % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= (OUTLET, INTERFACE_WJ_HOUSING) % % Marker on which to track one-dimensionalized quantities MARKER_ANALYZE = (OUTLET) % % Method to compute the average value in MARKER_ANALYZE (AREA, MASSFLUX). MARKER_ANALYZE_AVERAGE = AREA % % % % --------------------- OPTIMAL SHAPE DESIGN DEFINITION -----------------------% % % Optimization objective function with scaling factor, separated by semicolons. % To include quadratic penalty function: use OPT_CONSTRAINT option syntax within the OPT_OBJECTIVE list. % ex= Objective * Scale OPT_OBJECTIVE= SURFACE_TOTAL_PRESSURE; TOTAL_HEATFLUX % % Use combined objective within gradient evaluation: may reduce cost to compute gradients when using the adjoint formulation. OPT_COMBINE_OBJECTIVE = YES % % Optimization constraint functions with scaling factors, separated by semicolons : ex= (Objective = Value ) * Scale, use '>','<','=' OPT_CONSTRAINT= NONE % % Factor to reduce the norm of the gradient (affects the objective function and gradient in the python scripts) % In general, a norm of the gradient ~1E-6 is desired. OPT_GRADIENT_FACTOR= 1E-5 % % Factor to relax or accelerate the optimizer convergence (affects the line search in SU2_DEF) % In general, surface deformations of 0.01'' or 0.0001m are desirable OPT_RELAX_FACTOR= 1E3 % % Maximum number of iterations OPT_ITERATIONS= 100 % % Requested accuracy OPT_ACCURACY= 1E-10 % % Upper bound for each design variable OPT_BOUND_UPPER= 1000 % % Lower bound for each design variable OPT_BOUND_LOWER= -1000 % % Optimization design variables, separated by semicolons DEFINITION_DV= ( 11, 1.0 | INTERFACE_WJ_HOUSING | BOX, 0, 0, 0, 1.0, 0.0, 0.0 ); ...... Code:
Traceback (most recent call last): File "/app/su2/7.0.2/bin/shape_optimization.py", line 166, in <module> main() File "/app/su2/7.0.2/bin/shape_optimization.py", line 98, in main options.nzones ) File "/app/su2/7.0.2/bin/shape_optimization.py", line 138, in shape_optimization project = SU2.opt.Project(config,state) File "/app/su2/7.0.2/bin/SU2/opt/project.py", line 129, in __init__ group = historyOutFields[this_obj]['GROUP'] KeyError: 'SURFACE_TOTAL_PRESSURE' I also have the same error with the files from the tutorial "Shape Design With Multiple Objectives and Penalty Functions" in which OPT_OBJECTIVE=SURFACE_TOTAL_PRESSURE*-1E-4; (DRAG = 0.05)*1E6. It seems like SURFACE_TOTAL_PRESSURE and TOTAL_HEATFLUX are not defined for OPT_OBJECTIVE, because when I try with DRAG for instance, I don't have this error. Does anyone have an idea on how to solve this problem ? You can find my configuration file attached. Thanks, Nicolas. |
March 20, 2020, 20:49 |
Aman uz zaman Baig
Rep Power: 11 |
I have an issue open on GitHub for the same reason. I am looking into it currently.
https://github.com/su2code/SU2/issues/889 |
March 4, 2021, 15:53 |
Umut Can
Rep Power: 14 |
Were u able to solve?.I am having same problem for SURFACE_TOTAL_PRESSURE, could not solve it yet.
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 14:32 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
