Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Using multiple FFD_CONTROL_POINT's
Like Tree1Likes
  • 1 Post By wallym
Old   July 30, 2019, 16:14
Default Using multiple FFD_CONTROL_POINT's
Shreyas Kini
Shreyaskini20 is on a distinguished road
Hi all,
I am trying out the following test-case:
- Deform an airfoil (SU2_DEF)
- Compute the direct and adjoint solution (SU2_CFD and SU2_CFD_AD)
- Get the gradient of the drag with respect to the deformations for multiple FFD_CONTROL_POINT (SU2_DOT_AD)
I am trying the following syntax:
DV_KIND= FFD_CONTROL_POINT, FFD_CONTROL_POINT, ...
DV_PARAM= (SCB1, 0, 0, 0, 0, 0, 1); (SCB1, 0, 0, 1, 0, 0, 1); ..
DV_VALUE= 0.2, 0.2, 0.2, ..
On running SU2_DOT_AD I am getting the the following error:
[localhost:07682] *** Process received signal ***
[localhost:07682] Signal: Segmentation fault (11)
[localhost:07682] Signal code: (128)
[localhost:07682] Failing at address: (nil)
[localhost:07682] [ 0] /lib64/libpthread.so.0(+0xf5d0)[0x7f7b143da5d0]
[localhost:07682] [ 1] SU2_DOT_AD[0x67546e]
[localhost:07682] [ 2] SU2_DOT_AD[0x65128d]
[localhost:07682] [ 3] SU2_DOT_AD[0x671c96]
[localhost:07682] [ 4] SU2_DOT_AD[0x41e10a]
[localhost:07682] [ 5] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f7b14020495]
[localhost:07682] [ 6] SU2_DOT_AD[0x53bbee]
[localhost:07682] *** End of error message ***
I am using SU2 6.0.0 "Falcon".
Thank you very much for your help!
Shreyaskini20 is offline   Reply With Quote
Old   October 21, 2022, 10:09
mardar
mardar572 is on a distinguished road
I have the same problem also.
mardar572 is offline   Reply With Quote
Old   October 24, 2022, 12:07
Wally Maier
wallym is on a distinguished road
Hi Mardar572,
Can you explain more in depth your issues?
Are you using v6.2? If so, you should migrate to v7.4 as is it the most up-to-date.
wallym is offline   Reply With Quote
Old   November 4, 2022, 07:43
Default SU2_DOT_AD segmentation wault (core dumped)
mardar
Hi wallym,
I have two computers. One is ubuntu other ıs centos. They have exact same installation of SU2 7.4.0. Ubuntu can run the following tutorial without any problem.
https://su2code.github.io/tutorials/...ained_ONERAM6/
However, centos has a problem while running SU2_DOT_AD. As follows:
HTML Code:
---------- Start gradient evaluation using sensitivity information ----------
Evaluate functional gradient using Algorithmic Differentiation (ZONE 0).
1 Free Form Deformation boxes.
1 Free Form Deformation nested levels.
FFD box tag: WING. FFD box level: 0. Degrees: 10, 8, 1.
FFD Blending using B-Splines. Order: 0, 0, 0.
Number of parent boxes: 0. Number of child boxes: 4836.
Segmentation fault (core dumped)
Thanks
Old   November 7, 2022, 10:20
Wally Maier
Hmmm, I don' think I can help here. Could you post the SU2 github? This issue should get more traction there.
Thanks
mardar572 likes this.
dv_param syntax, ffd_control_point, multiple
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs Pier84 OpenFOAM Installation 4 June 18, 2016 17:22
[ICEM] Multiple edges asal ANSYS Meshing & Geometry 2 March 22, 2013 11:10
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
