January 6, 2019, 19:49 |
Can not run any test cases
Rep Power: 8 |
Hello everyone,
I am trying to run the test cases. I am running SU2 on Windows 10. My issue is that when I run the code, SU2_CFD runs for 1000 iterations (I have changed it to 1000 in the .cfg file). SU2_CFD exits without an issue but then I get the following error: Code:
Traceback (most recent call last): File "C:\SU2\bin\shape_optimization.py", line 187, in <module> main() File "C:\SU2\bin\shape_optimization.py", line 118, in main options.nzones ) File "C:\SU2\bin\shape_optimization.py", line 163, in shape_optimization SU2.opt.SLSQP(project,x0,xb,its,accu) File "C:\SU2\bin\SU2\opt\scipy_tools.py", line 143, in scipy_slsqp epsilon = eps ) File "C:\Users\myname\AppData\Roaming\Python\Python36\site-packages\scipy\optimize\slsqp.py", line 208, in fmin_slsqp constraints=cons, **opts) File "C:\Users\myname\AppData\Roaming\Python\Python36\site-packages\scipy\optimize\slsqp.py", line 315, in _minimize_slsqp for c in cons['ineq']])) File "C:\Users\myname\AppData\Roaming\Python\Python36\site-packages\scipy\optimize\slsqp.py", line 315, in <listcomp> for c in cons['ineq']])) File "C:\SU2\bin\SU2\opt\scipy_tools.py", line 467, in con_cieq cons = project.con_cieq(x) File "C:\SU2\bin\SU2\opt\project.py", line 256, in con_cieq return self._eval(konfig, func,dvs) File "C:\SU2\bin\SU2\opt\project.py", line 205, in _eval vals = design._eval(func,*args) File "C:\SU2\bin\SU2\eval\design.py", line 146, in _eval vals = eval_func(*inputs) File "C:\SU2\bin\SU2\eval\design.py", line 519, in con_cieq func = su2func(this_con,config,state) File "C:\SU2\bin\SU2\eval\functions.py", line 98, in function aerodynamics( config, state ) File "C:\SU2\bin\SU2\eval\functions.py", line 253, in aerodynamics info = su2run.direct(config) File "C:\SU2\bin\SU2\run\direct.py", line 96, in direct su2merge(konfig) File "C:\SU2\bin\SU2\run\merge.py", line 91, in merge merge_solution(konfig) File "C:\SU2\bin\SU2\run\merge.py", line 117, in merge_solution SU2_SOL( config ) File "C:\SU2\bin\SU2\run\interface.py", line 239, in SOL run_command( the_Command ) File "C:\SU2\bin\SU2\run\interface.py", line 302, in run_command raise exception(message) RuntimeError: Path = C:\Users\myname\Desktop\SU2_OPT\transonic_turb_constant_cl\DESIGNS\DSN_001\DIRECT\, Command = mpiexec -n 4 "C:\SU2\bin\SU2_SOL config_SOL.cfg SU2 process returned error '4294967292' ERROR: Error reported: failed to launch '"C:\SU2\bin\SU2_SOL config_SOL.cfg"' on myname-PC Error (2) The system cannot find the file specified. Regards, Lejonet |
January 7, 2019, 07:38 |
Rep Power: 8 |
The problem is still not solved so I am deleting the previous reply. I can not run discrete adjoint and continuous adjoint.
February 20, 2020, 13:20 |
Rep Power: 7 |
Same type of situation here: Git download on an up to date Fedora distribution. I think I installed everything needed but all shape design tutorials fail. The error message does not give any clue for me. Edit: some more details case: Inviscid_2D_Unconstrained_NACA0012 DSN_001 is created log_Direct.out in DIRECT is OK but log_Adjoint.out in ADJOINT_DRAG terminates with an error: Error in "virtual void CPhysicalGeometry::SetBoundSensitivity(CConfig*)": ------------------------------------------------------------------------- Surface sensitivity not found in file. ------------------------------ Error Exit ------------------------------- Here is the output error: Code:
Traceback (most recent call last): File "/home/myname/bin/shape_optimization.py", line 176, in <module> main() File "/home/myname/bin/shape_optimization.py", line 108, in main options.nzones ) File "/home/myname/bin/shape_optimization.py", line 152, in shape_optimization SU2.opt.SLSQP(project,x0,xb,its,accu) File "/home/myname/bin/SU2/opt/scipy_tools.py", line 133, in scipy_slsqp epsilon = eps ) File "/usr/lib64/python3.7/site-packages/scipy/optimize/slsqp.py", line 208, in fmin_slsqp constraints=cons, **opts) File "/usr/lib64/python3.7/site-packages/scipy/optimize/slsqp.py", line 423, in _minimize_slsqp g = append(fprime(x), 0.0) File "/usr/lib64/python3.7/site-packages/scipy/optimize/optimize.py", line 300, in function_wrapper return function(*(wrapper_args + args)) File "/home/myname/bin/SU2/opt/scipy_tools.py", line 400, in obj_df dobj_list = project.obj_df(x) File "/home/myname/bin/SU2/opt/project.py", line 238, in obj_df return self._eval(konfig, func,dvs) File "/home/myname/bin/SU2/opt/project.py", line 202, in _eval vals = design._eval(func,*args) File "/home/myname/bin/SU2/eval/design.py", line 147, in _eval vals = eval_func(*inputs) File "/home/myname/bin/SU2/eval/design.py", line 380, in obj_df grad = su2grad(this_obj,grad_method,config,state) File "/home/myname/bin/SU2/eval/gradients.py", line 96, in gradient grads = adjoint( func_name, config, state ) File "/home/myname/bin/SU2/eval/gradients.py", line 299, in adjoint info = su2run.projection(konfig,state) File "/home/myname/bin/SU2/run/projection.py", line 93, in projection SU2_DOT(konfig) File "/home/myname/bin/SU2/run/interface.py", line 187, in DOT run_command( the_Command ) File "/home/myname/bin/SU2/run/interface.py", line 292, in run_command raise exception(message) SU2.EvaluationFailure: Path = /media/data/myname/Logiciels/git/SU2/Tutorials/Inviscid_2D_Unconstrained_NACA0012/DESIGNS/DSN_001/ADJOINT_DRAG/, Command = /home/myname/bin/SU2_DOT config_DOT.cfg SU2 process returned error '1' |
February 20, 2020, 14:08 |
Eduardo de Oliveira Carvalho
Rep Power: 8 |
I noticed that your log points an error with SU2_SOL, what the specific log file of this error says?
You can find logs of each specific operation (e.g. SU2_CFD, SU2_GEO) inside the design directories. Maybe they can give you some clue about your problem. Best of luck Eduardo |
February 20, 2020, 14:45 |
Rep Power: 7 |
Thanks Eduardo,
Some new tests: it runs well with the DISCRETE_ADJOINT but it fails with the CONTINUOUS_ADJOINT option and the error is the one I quoted in my previous message: in log_Adjoint.out Error in "virtual void CPhysicalGeometry::SetBoundSensitivity(CConfig*)": ------------------------------------------------------------------------- Surface sensitivity not found in file. ------------------------------ Error Exit ------------------------------- |
February 20, 2020, 15:09 |
Rep Power: 8 |
Besides this message, is there another info inside the log?
Did it manage to run the SU2_CFD of the adjoint simulation? If it did the adjoint simulation, did it generate the "surface_adjoint" file? |
February 20, 2020, 15:36 |
Rep Power: 7 |
Yes, SU2_CFD runs properly and creates a surface_adjoint.vtk file
----------------------------- Solver Exit ------------------------------- All convergence criteria satisfied. +-----------------------------------------------------------------------+ | Convergence Field | Value | Criterion | Converged | +-----------------------------------------------------------------------+ | rms[A_Rho]| -13.0019| < -13| Yes| +-----------------------------------------------------------------------+ ------------------------------------------------------------------------- +-----------------------------------------------------------------------+ | File Writing Summary | Filename | +-----------------------------------------------------------------------+ |SU2 restart |restart_adj_cd.dat | |Paraview binary |adjoint.vtk | |Paraview binary surface |surface_adjoint.vtk | +-----------------------------------------------------------------------+ Code:
----------------- Physical Case Definition ( Zone 0 ) ------------------- Input mesh file name: mesh_NACA0012_inv.su2 Input sensitivity file name: surface_adjoint. |
February 22, 2020, 03:14 |
Rep Power: 7 |
Hello Eduardo,
What I have observed: DISCRETE_ADJOINT works flawlessly. Problems occur with CONTINUOUS_ADJOINT. SU2_CFD runs properly for the adjoint computation. Then SU2_DOT reads surface deformation parameters and then crashes when reading the the surface sensitivity file. What I have observed if that the input surface sensitivity file name is different when running CA and DA. With CA I get "Input sensitivity file name: surface_adjoint." when it is "Input sensitivity file name: solution_adj_cd.dat." with DA. Last edited by Lazlo; February 22, 2020 at 03:15. Reason: typo |
February 26, 2020, 06:58 |
#9 |
Tim Albring
Rep Power: 11 |
please make sure to add "SURFACE_CSV" to the OUTPUT_FILES option (default is "(RESTART, PARAVIEW, SURFACE_PARAVIEW)" )
Developer Director @ SU2 Foundation Get involved:
February 26, 2020, 14:31 |
#10 |
Rep Power: 7 |
Perfect !
There was no OUTPUT_FILES option in the tutorial cfg file. I have added: OUTPUT_FILES= (RESTART, PARAVIEW, SURFACE_PARAVIEW, SURFACE_CSV) And now, CONTINUOUS_ADJOINT runs perfecly on a single core. Solved for me Parallel run fails, but it is in an other topic... |
Big test cases | jacobH | SU2 | 1 | May 26, 2015 16:30 |
all rans and navierstokes test cases getting seg fault | jentink | SU2 | 14 | October 9, 2013 14:07 |
Change parameter and run cases parallel | lingdeer | ANSYS | 0 | July 29, 2011 10:27 |
Well Know Test cases should be on CFD-online | sam | Main CFD Forum | 8 | February 20, 2007 08:29 |
Standard CFD test cases? | Damon Qualski | Main CFD Forum | 1 | April 10, 2003 14:10 |
